Page 1 of 4 123 ... LastLast
Results 1 to 20 of 76
Thread: Mean Mr. Mustard
    Nov 2005
    2,002
    Default Mean Mr. Mustard
    '87 5 spd 50 HO Mustang.....so named after an '87 project 'Stang owned by Steve Collison from Cars Illustrated, SuperStock & Drag Illustrated, Muscle Mustangs and others as well as the Beatles song and the fact that it is Medium Yellow.
    It was garaged not long after my eldest Son was born. We are getting it back in the road for him to learn to drive. Gotta start 'em right!
    Do a burnout, pussy. Bobcat's Avatar
    Jan 2013
    West Granby, CT
    1,266
    Where's the pictures... And the burnouts..?
    Quote Originally Posted by SVT98t View Post
    I post a lot... 88Vic's Avatar
    Olathe, Kansas
    1,653
    I miss my old 87 LX 5.0/T5, it was a beast.
    Mine had a B&M shifter with stops, and I loved going through the gears with that. I'd install a shifter with stops, helps you not break the transmission too. Made the T5 feel solid.
    Also I felt the stock HO cam was weak in the low end, didn't come alive until about 2000 rpm. I don't know how guys here run it in their heavy cars with an AOD and high axle ratio. Maybe with lower gears than the stock 2.73's it'd be ok, but I'd rather install a better cam and be able to have longer gears. My car had BBK headers and o/r H-pipe, helped but still lacked the low end torque it could've had. I wish I had kept it long enough to install GT40 heads/intake along with a cam to really wake it up.
    37,519
    The HO stick is lame at low rpm. Needs gear to make one useful. Oddly enough, I got some low end torque out of mine with that SystemMax lower. The Mark VII is all the weight of a Vic with the same low stall converter and 3.27 gears. I wasn't expecting anything down low with that intake, but it definitely gave me some.
    Jan 2013
    West Granby, CT
    1,266
    Quote Originally Posted by 88Vic View Post
    Lower numerical number is a high ratio, high numerical number is a low gear ratio.
    Sounds stupid and is against logic, but it's how it works.
    HO cams aren't good for power, they just give these boxes a wee bit more hustle, for cheap.
    It has had various shifters in it, currently has a short stick Hurst. Stock H/C/I, it does have stock headers and a 65mm throttle body. It does currently have 2.73s. We are currently installing a 2.5 inch Pypes Violator catback. I think this should be copious for the current situation, AKA Im learning to drive in it
    Jan 2013
    West Granby, CT
    1,266
    Quote Originally Posted by tom-kat View Post
    it has had various shifters in it, currently has a short stick hurst. Stock h/c/i, it does have stock headers and a 65mm throttle body. It does currently have 2.73s. We are currently installing a 2.5 inch pypes violator catback. I think this should be copious for the current situation, aka im learning to drive in it
    is this jims son?
    Jim, is this your offspring?
    Nov 2005
    2,002
    Quote Originally Posted by Bobcat View Post
    is this jims son?
    Yes, scary isn't it...
    '10 Escape LTD. V6 AWD, K&N, VentVisors, Bullitt wheels.
    87 Ford LTD Crown Victoria Country Squire Station Wagon. 4.10's, Repacked Trac Loc, Boxed LCA's, Explorer Intake, 65mm T-body, 'Stang Cam, 'Stang Air tube, K&N, GT-40X Heads, 1" Spacer, 1 5/8 BBK's, 2.5" Pypes X-pipe w/high flow cats, Single Chamber Thunderbolts, B&M 'vertor, Po-lice Swaybars, Dead AOD.....
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts...
    20,908
    Quote Originally Posted by mitymerc View Post
    somewhat and very.
    Jan 2013
    West Granby, CT
    1,266
    Let's hope he can keep up the precious care towards car tires that his father shows!
    37,519
    And you let him on here with us nutters?
    Nov 2005
    2,002
    He better have some care & concern, I put brand new tires on it (the old ones were bald for some reason).
    Jan 2013
    West Granby, CT
    1,266
    Should've gotten him used ones. Rookie move!
    *laughs maniacally*
    We are probably going to finish the exhaust tonight.
    Sep 2014
    Warren, MI
    5,402
    Mean Mr. Mustard, cool Beatles tune.
    Jan 2013
    West Granby, CT
    1,266
    *laughs maniacally*
    By finish, you mean remove, right?
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,490
    Pics?
    '79 Continental Town Car *In storage.*
    '90 Crown Victoria LTD *In storage.*
    '94 Crown Victoria
    I practically live like it's 1993.
    20,908
    Colonel Mustard in the garage with the adjustable wrench...
    Nov 2005
    2,002
    Gotta clue?
    Nov 2005
    2,002
    Installed 2.5 catback Pypes Violator kit.
    Noticed that the tach no longer functions when we did the exhaust vid (to be posted @ a later date)
