Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 88
Thread: Mean Mr. Mustard
  1. #61
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,153
    No wonder the shocks don't work right, they're installed sideways.
    Rotate pic 90*....
    '10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts.
  2. #62
    Nov 2005
    2,153
    Is your son driving it? or another "toy" for you? Ahh, why can't it be both!
    Sadly, no. He does not have his license yet & his time is about up. #2 son is turning 16 & it's going to be his turn soon.
  3. #63
    Nov 2005
    2,153
    If I can pry it away from my wife it'll be a toy for me too LOL.
  4. #64
    Nov 2005
    2,153
    Attempted to replace serp belt.
    Derp.
    Seemed to be way too long. Didn't have time to mess with it. PN on old one indicates 91.5 the new one is the same... maybe I routed it wrong? May have time to try again tomorrow.
  5. #65
    Nov 2005
    2,153
    91" worked
  6. #66
    Nov 2005
    2,153
    Was next to a truck the other day. It sounded awful. Then I realized it was the Mean one....
    RPM dependant, wether moving or stationary... poked my head under the hood, couldn't tell if it was up high or down low. Oil 1/2 qt down. Got back to it a few days later, topped it off, no noise. Drove it for the 1st time since, noise is back. Full synthetic 10-30 with about 300 miles on it. HOWEVER oil change was done about 4 yrs ago, been sitting since. No time to look @ it today, going to a wedding.
  7. #67
    Sep 2008
    Whitestone, NY
    18,643
    Hopefully its okay!
  8. #68
    Nov 2005
    2,153
    Hopefully its okay!
    The innards of 1 cat are loose & rattling.
    Purchased a catted Pypes X pipe a few weeks ago, have not had time to install it.
    Also been kind of down on power, backfired once, does not pull in higher rpms.
    Rpl'd fuel filter, will check cap & rotor when I have time. Was installed 4-5 yrs ago & car just sat in garage till this summer. Don't recall if it was brass or crap aluminum.
  9. #69
    37,885
    my car was having some shuddering and general rough idle stuff, scraped the terminals in the cap and it stopped. It hadn't been run enough this year and the humidity caused the brass to fuzz up a bit.
  10. #70
    I post a lot...
    Mar 2007
    North Las Vegas Nevada
    2,235
    Think printed circut board atached they have been known to go bad.
  11. #71
    Nov 2005
    2,153
    Replacing clogged/rattling H pipe. Flow tube flange bolts came right off, header flange not so much....
    2 came out easily, 1 stud broke, 1 nut rounded off. Sawzalled the h-pipe between flange & O2 sensor. when I could get on the nut headon it came off grudgingly.
    The only way I could see to get the broken stud out of the header was to remove it & work on it on the bench. I figured that was half the job already so I ordered a set of Chrome BBK's. I could not find any 1 1/2" anywhere so I guess I'll be giving up some torque. The rest of the car is glaringly stock LOL.
    Also The Struts & Quad shocks were installed a few weeks ago.
  12. #72
    37,885
    yeah I don't think anyone makes the 1.5" anymore, even though they are better on the stock engine. The 1 5/8" really aren't any better than the stock headers on a stock engine.
  13. #73
    White collar, and a red neck P72Ford's Avatar
    Feb 2007
    In the 860
    7,139
    Is this car a coupe or a hatch?
    That color was fairly low production if I recall.
    **1965 Ford Mustang Coupe: Currently on the Rotisserie, 306/T5/4.10s Long Term Street/ Strip Project
    **1990 Ford Mustang LX Hatchback: 5.0, 5 spd, 4.10s; 30K original miles Cruiser
    **2012 Ford Mustang Boss 302: 5.0, 6 spd, 3.73s; 17K miles Cruiser
    **2008 CVPI, Ex MSP Unit #420: 4.6, 3.55TL Flowmaster 10 knock offs, dark tint, JD Blitz Black, DD, CHALKBOARD
    **2012 Harley Davidson Wide Glide (FXDWG): 103, Cobra Speedsters, Cosmetics
    **2014 Ram 1500 QCSB Express 4WD Hemi/8spd TF/3L21 Truck Duties; Boesch Built, Cosmetics
  14. #74
    Nov 2005
    2,153
    It's a hatch, I've only seek 3 others, 2 were 4 bangers, 1 had a sunroof.
  15. #75
    Feb 2007
    In the 860
    7,139
    156 5.0 LX hatch cars were built in medium yellow in 1987. Medium yellow was also referred to as "Jonquil", "Tropical Yellow" and Mimosa" over the years.
    I think between '87-'89 fewer than 500 LX 5.0 hatch cars were built. I would have a Marti Report done, as it may be pretty uncommon if it has some unique options.
    My Vermillion '90 LX hatch is one of 500 or so optioned that way.
  16. #76
    Nov 2005
    2,153
    The headers came out like they were installed yesterday. Got the new ones in & started on the X-Cat Pype. After much screwing around I compared them to the set in the 87 CS. No ceegar. one of the pipes is incorrect. They are shipping me a new one.
  17. #77
    Nov 2005
    2,153
    New pipe was received in 2 days.
    Been driving it. Still has fuel issue. I think the regulator and/or injectors are hosed.
    Ordered a new fuel level sender.
    It arrived in pieces. They sent a new one a few days later.
    Ordered a new fuel tank for the blue car, arrived damaged.
    Anyone noticing a trend here?
  18. #78
    37,885
    I believe I've got a good set of 19# around here if you need them. They came from my car when I upgraded to 24#. 95% certain I have them and know where they are. Which of course means I'll never find them.
  19. #79
    Nov 2005
    2,153
    Thanks Thain, I also have some "somewhere" they are JY take outs though.... Car stuff has to go on hold, tomorrow is my son's 20th B-Day & I go back to work Mon.
  20. #80
    Nov 2005
    2,153
    Have the tank out for new fuel level sender & inspection. The black plastic tank protector is dull & dirty. I have some "black trim restorer" I am debating that vs some black "plastic" paint.
