Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Weatherstrip and dew wipe sources
  1. #21
    V8 addict and rescuer of unsaleable Full Sizes
    Aug 2019
    46
    I measured around the window, about 62“ visible. The channel is 96“ out of the box. Does the rest go down the window slides that you don’t see unless the door panel is off? I believe I read one 96“ piece per front door.
  2. #22
    Aug 2019
    46
    Oh, just realized: when I said "felt inside, rubber outside" I didn´t mean inside/outside of the part, that was clear to me. I meant inside/outside of the window, so 1/3 of the channel sits on the outside of the window and is rubber, 2/3s sit on the inside of the window and that material is felt.
    Regards, Alex
  3. #23
    Sep 2008
    Whitestone, NY
    18,949
    More goes down into the doors. Nothing is a direct fit. It all had to be made to fit.
    Pretty sure when new the inside (where the window slides up and down in) was felt. The outside portion of it now looks like rubber because the weather took it’s toll on the material.
  4. #24
    Member
    Aug 2019
    Portland, OR
    43
    Has anyone used the Fox Body weatherstripping from LMR? Allegedly it is a reproduction of the later style 1993 seals and works for all of the Fox Bodies, seems to be a decent price at $40/pair. It appears to be cut long, so they might be long enough for our applications.
    https://lmr.com/item/LRS-20708AE-PR/...-Exact-Ford-Re
    Here is the PN from LMR LRS-20708AE-PR
  5. #25
    Sep 2008
    Whitestone, NY
    18,949
    Quote Originally Posted by kellen302 View Post
    No. I haven’t. Nice find. May work well for the four door cars. Would need two kits I’d imagine.
    Unsure if the length would cover the two doors.
    Seems worth a try if needing it. Sucks they don’t have a molded corner for the upper parts of the door. Easy to get around it though. Just cut the back side and leave the bubble seal untouched.
  6. #26
    Mar 2010
    Lewisville, TX
    21,439
    Nice find. Added to the top post as a possible option.
  7. #27
    Member
    Aug 2019
    Portland, OR
    43
    Has anyone figured out a replacement for the dew wipes on the tailgate window for Wagons? Or is it the same stuff?
