Anyone know if you can take the fuse box out of the dash (dangle it for good rear access to all wires) without removing the whole dash? My 88 has some weird electrical gremlins going on and I need to get at the wires to see what's up.
Fuse box removal
Fuse box removal
Originally posted by gadget73... and it should all work like magic and unicorns and stuff.Originally posted by dmccaigOverhead, some poor bastards are flying in airplanes.Tags: None
It extracts through the back. I've undone them before to get at the headlight switch, but I just shoved it off to the side. Not sure if there is enough wire to get it out and down below the dashboard to really work on it.86 Lincoln Town Car (Galactica).
Bah. I have no horn or cruise now. I have until August to figure it out as that's when inspection time is. Gotta have the horn to pass.
Time for the toggle switch special.__________________________________________________
No power to the fuse. So something is screwed.
it doesn't go through the relay first does it ?86 Lincoln Town Car (Galactica).
fuse first, then the relay... then the clock spring... yeah... kinda convoluted.
checked out the fuse box. All is good there. The problem is elsewhere. There's power at the fuse to the horn... but no power at the relay. Horn is connected to ground fine too (it's the last part of the circuit). May end up having to re-run the power wire from the fuse box to the relay. That will definitely suck. I wonder if there's a connector between the fuse box and the firewall. There's nothing between the firewall and the horn relay. BAH!
Probably just going to run a new power line.
EVTM would tell you if there is a connector. It might be part of that big white connector over near the relays that feeds all the header panel lighting stuff.86 Lincoln Town Car (Galactica).
Is it only your horn and cigar lighter that are dead? Looking at the '89 evtm, a fuseable link that feeds the horn fuse, also feeds other illumination (parking lights, mirrors, radio, door locks) and it is distributed in the fuse box.
Worn out fuse connector for #16? I'll assume you probed the connectors without the fuse in place for power. If none, then the fuse box may have a popped bus bar.
Alex.
just the horn and cruise. One horn works again (passenger side was ringing out at .4 ohm - basically shorted). Ran a fused 20A line from the battery to the power feed at the horn relay (cut it off from the fuse box) and I now have beep beep again... though only half as much. There is no connector between the fusebox and firewall on my 88. And from the firewall to the horn relay was a straight shot too. So I said F!@# it and just ran another line. I also figured out that my fuse box is wired differently from what my manual says. All the bus bars are good. I rang the whole thing out. It's just that one line between the fuse box and the horn relay that's shorted somewhere. Now I just need to replace the high tone horn behind the battery. Bah.
