I've finally made some progress, I forgot to consider how daylight savings puts a damper on my weekday fun time...!
My grand plan is to upgrade interior speakers and wire/arrange things so I can easily swap the amps and subs from one car to the other, and easily switch back to non-amplified in either one. This is largely inspired by my cheapness - it's one thing that's more powerful than my laziness. This laziness led me to do something... terrible.
Instead of running new wire through the door wire run, I opted to incorporate the factory wire It's plenty adequate size, and there was no need for additional connectors, aside from the connector pigtails for the speaker itself. I'd rather crimp than use the plug-in adapters!
My original plan was to snip the factory speaker wires behind the kick panel and feed them through it to the crossover attached to the other side. My disgust grew as I mocked up the crossover and prepared to drill, then I got some better ideas....
I found enough space to mount the crossover above the under-dash trim panel, and de-pinned the speaker wires from both halves of the convenient connector right there Just as I was thinking that it was working out a little TOO well, I remembered that the dash trim for the drivers side was missing. Lucky me, work was slow and I had just enough time left of my half-day for a solid hour of junkyard time. I still need to figure out where to attach the drivers side crossover, it's a bit tighter on that side.
The trim in the the last pic is only loosely in place for the pic, not done back there yet
