1. Can I wire the ECM connector for my mass air computer (A9P) but plug in my speed density HO computer (making sure to also supply manifold vacuum to the MAP sensor) for initial start up?
Yes, I know that the TAB and TAD wires will be in the incorrect position, though in the grand scheme of things they are deleted anyways….
Any thoughts, aside from it being silly to do this in the first place?
2. I would like to wire in the FPM at connector 19 for the mass air computer, now is that simply a 12dv+ after the fuel pump relay to tell the puter that the pump is theoretically receiving power?
Little background on the spec of the build:
• TFS top end kit but with explorer lower intake and lightning tubular upper
• Deleting smog pump, TAB, TAD as well as EGR (because the heads do not support EGR).
