Results 1 to 15 of 15
Thread: My Driveway J-mod Experience, 2000 MGM HPP around 186,350km
    Jul 2014
    Canada
    1,986
    Default My Driveway J-mod Experience, 2000 MGM HPP around 186,350km
    I’ve finally ‘recovered’ enough to provide a thread about my driveway J-mod experience. For those who haven’t seen Rizzo’s J-mod video yet, here's a link:
    http://www.grandmarq.net/vb/showthre...o-s-Jmod-video
    and here’s a link for other J-mod info:
    http://www.grandmarq.net/vb/showthre...E-4R70W-thesis
    As some may know, I like to suck out the tranny fluid through the fill tube. Here’s a pic of my setup:
    And here’s a pic showing how much is left in the pan:
    The tube actually gets stopped by the filter:
    I’ll probably cut the edge off the tube and see how that works.
    Here’s a pic showing how dark my fluid was:
ID:	44073Click image for larger version.
    It had been at least that bad when I changed my fluid in summer 2014.
    Here’s a pic showing how dirty my valve body was:
    I’m guessing the detergents in the fluid had been maxed out and couldn’t hold any more gunk.
    I left the springs in. For the hole sizes, I used ones provided by 88grandmarq. When I measured mine, they didn’t seem to be perfectly round, so I recorded the largest reading I could get. Here’s a table showing the intended stock, actual, and target sizes:
    1-2/2-1 shifts:
    #1....0.160.............0.166..................... .....no change required
    #2....0.081-0.089....0.067 (yup, six seven).....0.1015 (#38 drill)
    #3....0.180.............0.167 (yup, six seven)....no change required but I filed it to 0.180
    manual 2-1 downshift:
    #7....0.078-0.081....0.080....not needed but I did 0.125 for the helluvit
    I figured it might have some use in winter driving. I haven’t gotten around to trying it yet. I keep forgetting.
    2-3/3-2 shifts:
    #4.....0.81.....0.78.....0.110 (7/64 drill)
    #5.....0.81.....0.79.....0.110 (7/64 drill)
    holes in gasket for #4&5 need expanding, I wasn’t comfortable with a 1/8 punch so I just squared them out with a blade after checking the fluid passage pattern on the old gasket
    #6....0.125....0.131....0.160 (#20 drill)
    3-4/4-3 shifts:
    #8................not used....0.236.........................not used
    gasket slot 1..very thin....0.025...........................0.100
    #9..................0.081.......0.085............. .............0.110 (7/64 drill)
    #11................0.110.......0.067 (yup, six seven)....0.110 (7/64 drill)
    reverse:
    #10....0.078-0.081....0.070 (yup, seven zero)....0.089-0.093 (I used a 3/32 drill)
    When I checked some holes after drilling, they ended up being ~0.004-0.005 over the target at their widest points (though I haven’t noticed any issues). I was planning on recording the finished sizes, but I guess it slipped my mind. I would guess the enlargement is a matter of not drilling perfectly straight and/or having cheap drill bits. I ended up with a few nasty burrs too despite putting plywood underneath. I used a magnifying glass to make sure I cleaned them up properly.
    As per 88grandmarq's suggestion, I replaced the pressure regulator valve and boost valve and sleeve. Boy did it need them:
ID:	44076Click image for larger version.
    While the pics make it seem that the wear on the pressure regulator valve was only in one spot, there was a little bit of wear apparent on the opposite side too. I hadn’t noticed any obvious issues with how the car drove, and it’s not something I would have thought of myself, so a big THANKS!! to 88grandmarq.
    Since I’d heard about tranny filters occasionally working their way loose and falling into the pan, I decided to use some galvanized strapping to keep it in place (especially after seeing that the suction tube hits it). I put a long piece under one valve body bolt and a short piece under another valve body bolt and bolted them together after the filter was installed:
    I actually had a helluva time getting the filter in all the way. Getting it in part way was easy enough, but it obviously had more to go. I positioned myself to get as much pushing force from my hand as possible, and I was worried about bending the damn filter, but it eventually went in. I’d guess at least some cases of the filter falling out is people not realizing how far it’s supposed to go in.
    I didn’t bother cleaning the pan magnet and checking the old filter until afterwards. The thick stuff on the magnet seemed normal enough, but I ended up finding a few slivers of metal among that stuff when I cleaned it. I also found a bit of metal in the filter:
    Are there any scenarios where bits of metal don’t indicate the start of an eventual premature failure?
    Performance wise, the effects have been more subtle than dramatic, but that’s just fine since I’m only interested in the life-prolonging benefit rather than anything else. If my mind is elsewhere and I’m driving casually, I might not even notice the shifts. Now that I think about it, I haven’t really noticed anything significant with the downshifts, though I haven’t really been paying attention to those. Most of the time I can feel the up-shifts. Whereas before I could not really tell when 1-2 was happening, I can tell now. It’s kind of annoying knowing 1-2 happens during turns from a stop.
    I reserve my WOT use for the highway, so I don’t know if 1-2 will chirp a tire (with open diff), but 2-3 certainly does. I really need a tire rotation now.
    One annoying thing is that reverse wasn’t benefited as much as I was hoping. The shift itself is more pronounced, but it seems that the time between the lever going into R and the start of the shift is still long. This is how I am about that:
    https://youtu.be/3-vMzPi3IDg?t=1m11s
    Overall, very happy. Thanks again 88grandmarq!
    Jul 2014
    Canada
    1,986
    I was going to include all of my tranny filter autopsy pics in the above post, but there's a 10-pic limit, so here are the other three:
ID:	44081Click image for larger version.
ID:	44082Click image for larger version.
    39,086
    That is some awful dark and nasty fluid. Do you have a trans cooler? If not, I'd add one. Making the fluid run hot is usually a big factor in how fast it gets dark. Its also a big factor in how fast the trans dies.
    Jul 2014
    Canada
    1,986
    It has a cooler, though no idea if it actually works. According to my father's service records, he had a pan drop and filter change at ~50,000km (why the dealer didn't do a TC drain is beyond me) but nothing after. When I got it around 125,000km, I did a suck and fill with generic Dex/Merc without realizing it was supposed to be Mercon V. With the car tilted forward, I get ~4L out. When I learned about the Mercon V spec, I did another suck and fill, and I'm pretty sure another after that. It was only in summer 2014 that I learned about the TC drain plug and did a TC drain with a suck and fill. I got ~9L that time. The J-mod fluid change was ~11L. I've just been figuring it's a matter of not having changed the fluid often enough (much like my black brake fluid). Is there an easy way to test the thermostat on the cooler?
    At least the drops on the valve body are red. If those were dark, then the tranny would probably be as good as dead.
    21,531
    Trans fluid cooler should not have a thermostat in it. It should just be straight through.
    Hey... That was your 1000 post!
    Sep 2014
    Warren, MI
    5,827
    The Yosemite Sam thing was hilarious.
    Jul 2014
    Canada
    1,986
    It looks like one of those 98+ things:
    http://www.crownvic.net/ubbthreads/u...67#Post1895967
    39,086
    take the car for a drive and see if the tubes on the cooler side of the thermostat get hot or not. If it doesn't, then the thermostat is probably not working. I kinda like the concept of a thermostatic bypass but its a possible point of failure. There is a magic temperature range with oil filled equipment where you get the best life and performance out of both the equipment and the lubricant. Its usually not "as cold as you can get it".
    21,531
    well isn't that just something else to go wrong. Bah. I'd replace it with an aftermarket that keeps is as cool as possible. But then I'm in Texas and it never gets cold enough for us to really have issues with needing to warm up the trans fluid.
    Jul 2014
    Canada
    1,986
    Quote Originally Posted by Steveh66 View Post
    says the guy who joined a month before me but only has 21.
    Here's a link to a thread started by a guy in Texas (assuming his location hasn't changed) who bypassed the thermostat in January 2012:
    http://www.crownvic.net/ubbthreads/u...Number=2432200
    21,531
    too bad he didn't post pics or any real explanation, of course if I ever run across that issue... I can probably figure it out easy enough.
    Bahah... Ya.. Not really a posting guy.
    But great post and pic. I'm rebuilding my 4R70W now so its very timely.
    Steve
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,304
    Because the only people who do a torque converter drain are cvn'ers going overboard and maybe transmission shops. A pan drop and filter change is the typical trans service.
    Alex.
    Jul 2014
    Canada
    1,986
    Alex.
    If you're suggesting that changing only 1/3 of the fluid at a time is what's best for the tranny, I would strongly disagree.
