Ford Premium sound 1986 - 1991 Wiring
    Just doing some testing with the factory wiring to find what colors go to what speakers in the ford Premium sound. This is off my 86 Grand marquis. I believe the information should be relevant to the years in the title. Can someone confirm that? This is a basic system no EQ I don't believe there are any extra/hidden amps in the system other than the head unit. This is a draft and the information may not be accurate, especially in regards to the power section
    Also I have gotten rid of my wiring harness so I will also note which wires go from one harness to the other.
    Power:
    Orange W/ Blue dot - Orange W/ Blue line (Switched? 12V+)
    Yellow W/ Black dot - Yellow W/ Black line (Constant? 12V+)
    Green W/ Yellow - Green W/ Yellow (Dimmer?)
    Blue W/ red - Blue W/ red (Illumination?)
    Ground Chassis
    Speaker:
    FL+ Orange W/Green dash - Green (bright)
    FR+ White W/Green dash - White w/ Red stripe
    F - Black W/White dash - Black
    RR+ Pink W/Blue line - Orange W/Red stripe
    RR- Green W/Orange dots - Green W/Orange line
    RL+ Pink W/Green line - Pink W/Green
    RL- Pink W/Blue dots - Pink W/blue line
    The car wire colors are going off of my notes. I'm looking only at the amp right now so sorry if the wording is inconsistent. I think a stripe and a line are the same thing. I'm quite sure the polarity is correct and consistent based on radio listening tests.
    Current ride: 2004 "The Distant future" Grand Marquis
    I forget what I scanned this from, but its probably out of a 1986 EVTM
    http://gadget73.com/images/schematic/conventional.jpg
    http://gadget73.com/images/schematic/electronic.jpg
    I believe this changed somewhere along the line, probably around 1988 when the radio changed.
      89 definately has negative outputs for both front speakers.
      Past Panthers
        my 88 has the two rectangular single row 8-pin connectors. two wires to each speaker. But it's not premium sound either... so that may be the difference.
          As far as I know, premium sound always involved the amplifier. Straight off the radio was just electronic am/fm/cassette or whatever particular radio you had.
          There also appear to be two variants to the football amp rig. There is a 4 channel version and a 2 channel. My Towncar in stock form had only the front speakers fed through the football. Rears were straight off the radio.
