Results 1 to 13 of 13
Thread: Keyless entry and remote on a 2000 MGM
    Minivans are tangible evidence of Evil.. 85MercPark's Avatar
    Jun 2005
    Harrisburg, PA
    3,394
    Default Keyless entry and remote on a 2000 MGM
    So my 2000 Marquis has the keypad for entry but when I bought it there was no remote key fob. Did they all have a key fob or is that an extra option?
    2000 Grand Marquis LS
    Mercury Owners Group member
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,166
    Keyless was an option. And keyfobs changed around 1998/99 if you are yard hopping. So stick to something from 99-2002. Find some correct part numbers for 2000 and visit a yard, find out if they have a bucket of fobs. (the yard I goto has a few bucket of fobs, litterally, a ford bucket, an imort bucket, a gm bucket behind the counter.
    Alex.
    Jun 2005
    Harrisburg, PA
    3,394
    Is there a way to know if mine had the option?
    20,804
    If you have the keypad... and it works... you should be able to get a keyfob to work with it. Look for the 4 button fob. Should have the blue trunk button bottom right and panic bottom left. My 2000 has a 98 part number FOB (ORIGINAL) and a 2003 part number spare. Got mine off ebay for like $15. look around and be patient.
    Jun 2005
    Harrisburg, PA
    3,394
    Great. Thanks.
    Jun 2005
    Harrisburg, PA
    3,394
    Key fob on it's way...
    20,804
    Once you get it... you'll need to know how to program it.
    Programming —Transmitter
    NOTE: Keyless entry remote transmitters can also be programmed using a scan tool and the Ford Service Function (FSF) card.
    Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
    NOTE: When the first remote transmitter is programmed, all other remote transmitters are erased.
    Press any button on each transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
    If additional remote transmitters are to be programmed, repeat Step 2 within 7.5 seconds or steps 1 and 2 if more than 7.5 seconds have elapsed.
    To exit program mode, turn the ignition to START or wait 7.5 seconds.
    NOTE: Failure to wait at least 20 seconds will cause programming failures.
    Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification.
    Programming —Autolock and Horn Chirp
    NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
    Press the UNLOCK button three times.
    Turn the ignition switch to OFF.
    Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
    Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
    Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
    Jun 2005
    Harrisburg, PA
    3,394
    Yea. It worked. Thanks.
    20,804
    I just got this car and it has a number pad on drivers door and the numbers are handwritten in the manual. That works great. But car came to me fob-less. If I get a fob, should I be able to program it to the car? Does presence of number pad mean keyless fob system is already in the car?
    "In an insane society a sane man would appear insane." --Spock to Kirk
    2008 GM LS in Smokestone Metallic
    Dec 2011
    Yonkers NY
    3,833
    here is 2 examples of different extremes. You may want to buy new oem ford stuff as opposed to the cheaper junk but these should work. Plenty of all types and conditions out there. There is a FCC ID # on the back of the transmitter. If I dig up my original fobs for the Lincoln I will post the ID but someone with them on their keyring might just post in. As posted earlier in this thread junk yards may have piles of them.
    https://www.ebay.com/itm/2Pieces-Key...8AAOSwiJZcDtzK
    https://www.ebay.com/itm/Ford-OEM-Re...temCondition=3
    20,804
    If the keyless entry keypad is there... you should have the ability to program a fob.
    I did get a free 3 button fomoco fob today from guy who sold me the car two weeks ago. I tried the procedure on here calling for four turn on cycles but car never entered program mode. Search on bing said do it 8 times, not 4 so I did and YAY it did go into program mode and fob button did trigger lock unlock cycle and all seems well. THank you.
