Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 82
Thread: My '05 MGM
  1. #61
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Quote Originally Posted by VicCrownVic View Post
    My experience has been that the manifold to head studs/bolts are no problem to get off. Manifold to downpipe/cat studs are the real pain, but at least can be dealt with on a bench.
    Edit: I'm talking about box exhaust, not sure how/if whale exhaust behaves any different.
    I didn't have any problems getting the lopo exhaust bolts out. The only other vehicle that was easier was my Malibu; but I suspected that its 305 had been replaced prior to me getting that car.
  2. #62
    Nov 2006
    Dirty Jersey Yo!
    8,550
    I have the driver side tailpipe mocked up for the most part. I got a bunch of 45 and 90 bends; but I discovered that I need 30 and 60 bends as well. I will order those along with the hose ends. For the driver side, it looks like I need 4 x 90 to go over the rear axle, one 60 bend, one 45 bend, and a 30 bend to pitch it to the rear bumper. We'll see when those parts come in.
  3. #63
    Nov 2006
    Dirty Jersey Yo!
    8,550
    I received those bends and laid them out. The piping is now very close to the stock tailpipe; just needs to be cut down to fit on a couple of the straight sections. I'm gonna leave it a little long until the time comes to put everything up. Then I will cut and trim as needed; but the basic routing is done. Now I need to do the same to the passenger side.
  4. #64
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Not much going on here. Over the weekend, whilst clearing out the basement, I found the heat shield I got from the junkyard some years back. Cleaned and painted it. I think when an engine isn't too rusty and greased up, it's treated a little better at the shop; unless I go crazy and start putting on hot pink paint or something.
ID:	55585 Click image for larger version.
ID:	55586 Click image for larger version.
  5. #65
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Changed things up a bit with this car. I procrastinated with the winter wheel setup until 2 weeks ago; and pulled the trigger on the Saleen wheels. Since they sit wide; I have to be careful about the terrain; and keep away from dips and humps; as the rear tires rub the fender. If I am good with changing these out every season; these will last a while. I still have the 1st set of summer rear tires on the Crown Vic. I am still up in the air on whether I like the look. If I decide that I don't like them; I will throw them on the Crown Vic when I do the bigger big brake swap.
    Pics
ID:	55990 Click image for larger version.
  6. #66
    Nov 2012
    Shelby Township, MI
    3,661
    They fit the car as far as appearance goes. Not my style, but neither is my car (it's growing on me LOL).
    edit: what's up with the keypad?
    ~ 1991 Mercury Grand Marquis LS "The Scab" - plenty of rot, backup/summer cruiser
    ~ 1997 GMC Yukon SLT - wannabe winter DD - many issues, returning sometime in the 2020s
    Gone but not forgotten:
  7. #67
    Nov 2006
    Dirty Jersey Yo!
    8,550
    I discovered shortly after getting this car; that the alarm would go off by itself on rainy humid days. I saw that the keypad is dry-rotted and letting water in and onto the alarm sensor; thus setting it off. I don't remember who on this site told me about that. I probably should have epoxy'd it, but at the time, I just taped it up and kept doing so. Rough on the paint, but the car will need a repaint in the near future anyways.
  8. #68
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Installed one of the catch cans between the valve cover and air intake tube. This is a temporary set up as all was had at the local auto parts store was 5/8" heater hose. I will see if I can get 5/8" fuel hose instead. I was going to install the catch can for the PCV hose; but I couldn't find any fittings that would work. I will see if I can find a hose barb 5/8" to 1/2" adapter so I can use the Steeda can I got. I also got the car inspected; so I can start thinking about the dual exhaust conversion again.
    Pics
ID:	56061 Click image for larger version.
  9. #69
    Nov 2006
    Dirty Jersey Yo!
    8,550
    I couldn't get motivated to go out and work on the Crown Vic today. So I decided to tackle the Grand Marquis PCV catch can project. Since the ports on this Steeda catch can are 1/4" NPT (I wrongly stated 1/2" npt above); and the PCV valve and throttle body PCV ports are 5/8"; I initially tried to step it up with adapter fittings from Home Depot. That made the hose run way too long and I couldn't get it to fit. Last week I was ordering house supplies from Amazon and remembered to look up and order 1/4"NPT to 5/8" barb fittings. That made the hose run much shorter. I had forgotten that the fuel supply line is in the way; so I routed the hose around it. Doesn't look too bad; and it should serve its purpose.
    Hopefully tomorrow will bring better weather to work on the Crown Vic.
    Pics
ID:	56361 Click image for larger version.
  10. #70
    Nov 2006
    Dirty Jersey Yo!
    8,550
  11. #71
    Nov 2006
    Dirty Jersey Yo!
    8,550
    So the new tradition for turkey day is to do major repairs on my vehicles. 2019 I replaced the coils and plugs on my Grand Marquis; 2020 I replaced the intake manifold; yesterday I replaced the front brakes and sway bar. My brake pedal had been progressively getting lower to the floor since last spring. The pattern for this car is they begin to grab more towards the end of their service life; which they started doing in September. Then last month I started seeing the brake light on the dash flicker; and the last couple of weeks I was getting significant brake fade; so much so that I was driving very conservatively.
    The sway bar is another story. I attempted to switch it out back in 2019 and broke a sway bar retaining clip in the process of removing the old bar. In fear of breaking the other retaining clips; I stuck a carriage bolt and a locking nut in its place. I left the old bar in place while I looked for replacement retaining clips; that I discovered were discontinued by Ford and none could be found locally. During that interim, my carriage bolt worked its way out and fell off; which stressed the other passenger side retaining clip; which broke and fell off at some point. I didn't notice it until I slapped the Saleen wheels and wider tires on the Merc and noticed no improvement in handling. In fact, it was beginning to roll a bit more than usual. I knew something was up; but didn't know how bad it was until I jacked the car up yesterday and found that side of the sway bar dangling by the end link; and the metal bushing bracket was nowhere to be found. Fortunately I had gotten retaining clips for another Ford vehicle off of Amazon a month ago; so I spent some time (with a hammer and punch) making them fit. Then I removed the old sway bar and replaced it with one from ADTR (much thicker). In a couple hours I will see if the driveway is dry enough to replace the rear brakes. Then I will take the car out tomorrow to begin bedding the pads and see if I got some handling back. I will also change the oil while I am at it.
    I am having issues loading pics, so I will try again later.
  12. #72
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,210
    I sold the nos Ford rubber body side moldings for a CV/MGM today. Very good sale. Helped my wife put up the Christmas tree and decorations. She gets allot of pleasure doing this every year.
    Need to swap cars around in the garages. Need the LTC signature in the heated garage so I can replace the vinyl top this winter. Can't move cars today as the ground is soaking wet and it is suppose to snow the next couple of days.
  13. #73
    Nov 2006
    Dirty Jersey Yo!
    8,550
    I wish we had a heated garage; let alone a garage to work in. I have to get back on fighting with the home insurance to cover the garage replacement.
    As such, I replaced the rear rotors and pads Saturday afternoon. It could be just my car; but my axle hubs are under-bored; as everything that is mounted to them gets seized. The original wheels, the 1st set of PI wheels, and the Saleen wheels have to be pried off the hub. As such, I used a 3-jaw pulley puller to remove the rear rotors since hammering does nothing. When I put the wheels back on yesterday and went for a test drive, I heard and felt a knocking noise from the rear wheels. When I got home I jacked the car up and pulled the wheels off to see what was up. I readjusted the e-brake and spun the wheel by hand and it clunked and binded up. It was dark and my hands were freezing, so I called it a day. Went out this morning and pulled the brakes apart on the driver side to discover that the brake shoe retaining clip and pin came apart and basically pulverized themselves somehow. Waiting for new brake shoes and hardware to come in so I can complete this task.
  14. #74
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Pics
ID:	57258 Click image for larger version.
ID:	57259 Click image for larger version.
  15. #75
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Pics
  16. #76
    Nov 2006
    Dirty Jersey Yo!
    8,550
    More pics........
ID:	57262 Click image for larger version.
ID:	57263 Click image for larger version.
  17. #77
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,210
    I like the new sway bar and mounts.
  18. #78
    Nov 2006
    Dirty Jersey Yo!
    8,550
    I spent yesterday afternoon installing the e-brake shoes; and adjusting them. My old method was adjusting them all the way in, jacking the rear of the vehicle up, and slowly adjusting them until there is resistance. When I put the wheels back on and spun them; they were very tight; and that was before messing with the e-brake. Long story short; the few times I have messed with drum brakes and e-brakes; I had been doing it in PARK. The mechanic in my town said I needed to put it in neutral as there will be resistance in PARK. So I have been doind this wrong for a long time. Also, when I went for a test spin this morning, the brakes are tight and the EBC rotors and pads are very grabby. As such; when I put it in DRIVE and let go of the brake, it barely moves. I drove it to work and I can hear a slight dragging from the brakes. I'm going to guess that is part of the bedding process.
    And my sway bar is hitting the wheel or something when I make a sharp turn. I will have to look at that on the weekend.
  19. #79
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Also more pics.......
ID:	57267 Click image for larger version.
ID:	57266 Click image for larger version.
    Attached Files Attached Files
  20. #80
    Nov 2006
    Dirty Jersey Yo!
    8,550
    Those EBC brakes that I installed on the Grand Marquis paid for themselves last night. On my way home from work; the cars in my lane slammed on their brakes to avoid somebody's bumper. Since both lanes to either side of me were moving I initially tapped on the brakes; then I realized that they weren't just brake checking; and I put a good amount of pressure on the brake pedal. Came to a stop about 10ft away from the Jeep's rear bumper in front of me. Had this been the SP Performance brakes I had on there previously; I would have rear ended that Jeep. When I complete the GT500 rotor/C5 caliper upgrade for the Crown Vic; I will look into doing the same for the Grand Marquis. Can't have too much brake for these heavy cars.
