My '05 MGM
    Getting a good look at the pictures; it looks like there is a gap at the bottom where the intake meets the cylinder head. Not sure if it's just an O-ring there or some other type of gasket. I wonder if it's possible to smear some Permatex in that gap for a patch until I get another replacement intake?
      Just got done with the intake manifold swap. I will post pics tomorrow. It runs no differently than it did before; aside from the lack of the coolant steam show it displayed last Wednesday. I noticed after I got it running that I got fluid running off of the EGR pipe and dripping onto the intake manifold. Is this normal; or did I jostle the EGR pipe the wrong way?
        Pics of the disassembly process. The lifter valley had a good pool of water mixed with coolant when I took the old intake out. I guess it was leaking for a long time.
ID:	1288328 Click image for larger version
ID:	1288329 Click image for larger version
          Shouldn't be any drips, but I'm not sure what would be dripping from the EGR Pipe unless it's condensation.
            I noticed it when I took it to the gas station to fill up. Popped the hood and saw a line of water running from the bottom of the TB. I traced it to below the EGR pipe. I will get a better look tomorrow when it's not raining.
ID:	1288331 Click image for larger version
ID:	1288332 Click image for larger version
                I mentioned it in the What Are You Working On thread; I did my best to clean the engine off before disassembly; yet I still managed to get an acorn into one of the intake runners. Spent 1.5 hours fishing it out with cut and bent wire coat hangers. Then I had to take a couple throat culture swabs and some elmers glue on the cotton tips to yank out other small bits. I broke the pcv hose when I removed it; despite removing as gently as I could, it still snapped. Also, as I was removing the old intake; my elbow ran into the fuel vapor purge solenoid and snapped a port off. We tried to epoxy it, but there was a tiny piece of plastic that was missing; so I got a new solenoid and installed it in its place. That was some of the fun of this process. Day by day, I hate squirrels more and more.
                  One thing I realized during that process; when I go to do the full exhaust on this car; I will remove the EGR valve and the driver side exhaust manifold and take it all out in one piece. I tried to remove the pcv hose from the valve and it wasn't budging. I can only imagine that it would be much more difficult to remove from the exhaust manifold. I'm simply going to replace the EGR system when I install the headers. Hopefully that will make that process easier.
                    Easiest way to get dirt and crap out of tight places is often compressed air, I've also used a vacuum with some small plastic pipe taped on the nozzle.
                    With compressed air, definitely cover your eyes and any other places you don't want said crap to fall into.
                      I bought a Central Pnuematic compressor for the purpose of clearing out debris. I used an O-ring puller to get at the things crammed between the valve cover flange and the intake gasket (very small space). I missed an acorn. This, after having cleared out debris when I swapped plugs and coils a year ago. Also want to cover your mouth; I had coolant, debris, and a little oil splash on my face when I first did that. Didn't taste good at all.
                        I started the full exhaust conversion today by soaking the exhaust manifold studs with PBBlaster. I am going to find some liquid wrench and use that later on. But for now, I am going to soak the studs every other week until March; then it will be every week until I decide to do this. I’m also going to try fitting different tools (probably air) in the tightest spaces to see what will work the best. Also also, I began mocking the driver side tailpipe. I need to purchase some more 90* and 45* bends for the passenger side. I hope to have this all figured out before I break the first exhaust manifold stud.
                          Thinking way ahead. Hope it goes smooth when the time rolls around.
                            I hope so too. I also got a bolt extractor kit as I anticipate broken studs; judging by the condition of what's on there now. Hopefully a few months of soaking and heat cycles will coerce them off of the heads without breakage. I have leftover pipes from the CV dual exhaust conversion from a decade and a half ago. I was going to use them for some of the current CV exhaust; but as was seen, I messed that up and went dual 3" to the axles. I have a few more 90* and 45* bends to purchase to complete both tailpipes. Also, I found that my Ranger exhaust, although under some debris, was not damaged by the tree. I am going to dig it out and use it when I cut the passenger side of the exhaust from the MGM. I also salvaged the exhaust tip I used on the Ranger too; I will just put a 90* bend after the muffler and run a side exit for the next few months.
                              My experience has been that the manifold to head studs/bolts are no problem to get off. Manifold to downpipe/cat studs are the real pain, but at least can be dealt with on a bench.
                              Edit: I'm talking about box exhaust, not sure how/if whale exhaust behaves any different.
                                I'm cutting it all off and running full length headers, high-flow cats, and full exhaust. I found in the past that it's worth the effort on a daily driver; especially going from stock manifolds and a single exhaust.
