View Post
- bore (where the pin from the plastic TV cable blocke goes in: 6.41mm, 0.252"
- OD of the stepped-down section that goes into the TB lever: 10.7mm, 0.422"
- height/thickness of the stepped-down section for TB lever: 2.93mm, 0.115"
- OD of the "shoulder" section between cable block and lever: 15.01mm, 0.591"
- height/thickness of said shoulder section: 2.93mm, 0.115"
- overal height/thickness of entire bushing: 5.86mm, 0.230"
Took each measurement twice, in both metric and imperial, so 4 times total each. Any mismatch in numbers is due to inaccuracy of calipers, it's just a cheap HF digi unit.
