Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Electric Fan swap relay?
  1. #21
    GMN Regular merc91's Avatar
    Jun 2008
    Ontario Canada
    920
    I run 2 of the hurrican force winds taurus fans each on a seperate relay triggered by my afternarket ecu but plain jane 40a relays work fine but i popped in 80a versions anyways. You could just trigger the relay(s) with a basic grounding $20 temp switch that grounds at whatever temp it's desined to do do... Have your ground wire of the relay run to 1 of those threaded into idealy an upper intake- pre-rad coolant source and you're gold.
  2. #22
    Member magnus77's Avatar
    Mar 2015
    Ontario
    79
    So i bought this ford multi speed fan relay from this site:
    http://www.dccontrol.com/relay_controllers.htm
    Should solve the problem. Came in today, it's a two speed controller with a temp adjustment.
    1985 LTD Crown Vic, factory hard top, 302 soon to be gt40p headed (lightly ported & blended), summit brand stealth (port matched), stock cam, summit annular 600cfm VS, dual exhaust, 3.55 LSD, AOD, electric fan swap, tan interior.
Tags for this Thread
