You may need to repin a few things and get a stand-alone cruise control module and wire that in to maintain cruise control if the cruise is controlled by the ECM.
So...shift kits/valve bodies
Originally posted by knucklehead0202 View PostWhat computer are you running gadgo? Pretty sure any MAF mustang computer should work for me and I may not even need to fuck with the harness since it's already a MAF harness, but we'll see. Even if not, i'll have access to the mustang harness anyway since my brother's car is getting a standalone.86 Lincoln Town Car (Galactica).
Originally posted by knucklehead0202 View PostI have a free A9L computer out of an '89 so it should be a good starting point..
A9M 5.0 1989-93 Mustang MAF / Auto
A9P 5.0 1989-93 Mustang MAF / Auto
C3W 5.0 1989-93 Mustang MAF / Auto
C3W1 5.0 1989-93 Mustang MAF / Auto
A9T 5.0 1989-93 Mustang MAF / Auto
8LF 5.0 1989-93 Mustang MAF / Auto
8LG 5.0 1989-93 Mustang MAF / Auto
Also what size maf is on that thing? i bet its tiny!Rodney Tolleson, me at the track.....future drag box racer!
yeah, the manual one and the auto one are different with the neutral safety switch. I forget particulars but one switches ground and the other switches hot, and if you get it the wrong way round it will partly smoke the ECM. It usually still works but you can't do a self test because the ECM doesn't know when you are in or out of gear, and it usually makes the startup and decel go funny for the same reason.86 Lincoln Town Car (Galactica).
So the DA1 from an 87 T5 car I have probably won't be good to use until I get a T5 or do some botch wiring (I'd be staying speed density)?1990 Country Squire - weekend cruiser, next project
Clever use of a relay could probably fake this out with no real bother. You'd just have to look up both circuits and use the relay to simulate the other one.86 Lincoln Town Car (Galactica).
Originally posted by Tiggie View PostSo the DA1 from an 87 T5 car I have probably won't be good to use until I get a T5 or do some botch wiring (I'd be staying speed density)?
DA1 5.0 1986-88 Mustang SD-SFI / Manual
DB1 5.0 1986-88 Mustang SD-SFI / Manual
DC 5.0 1986-88 Mustang SD-SFI / Auto
DE 5.0 1986-88 Mustang SD-SFI / Auto
GJ1 5.0 1986-88 Mustang SD-SFI
VH2 5.0 1986-88 Mustang SD-SFI
VJ1 5.0 1986-88 Mustang SD-SFI
VM1 5.0 1986-88 Mustang SD-SFI / Manual
VP1 5.0 1986-88 Mustang SD-SFI / Manual
VR1 5.0 1986-88 Mustang SD-SFI / Manual
D9S 5.0 88 Mark VII SD-SFI
DX3 5.0 87 Mark VII
DY3 5.0 88 Mark VII
VL2 5.0 87 Mark VII
M1L1 MK7
Funny thing is i have 3 A9L's laying in the shop with various problems..........leaking capacitors, 1 burnt sig trace, 1 burnt resistor..........all were junkyard finds......just to lazy to fix'em lol.............Rodney Tolleson, me at the track.....future drag box racer!
Thanks for the tips guys. And yes, the stock maf on this thing is a friggin' joke it's so tiny. Guess i'll poke around for a different computer, or talk to my buddy at the auto-electric place and see if he's got ideas. Hell they may even have the computer I need. That's the shop that's gonna be putting on my top end here soon so i'll figure it out then.
The caps are easy, the rest of it ranges from no big deal to scrap metal, depending.86 Lincoln Town Car (Galactica).
Before my lentech aod, I had my stock aod but with a silverfox vb in it and it was great. I did buy the transgo shift kit for my 91 and I had the vb on the workbench and wanted to make it work but i can't remember exactly what it was but it was just not going to work. So I did the silverfox thing. The car had 50k miles but after the explorer heads/intakes at 240rwhp the trans would slip like mad at the 1st-2nd shift until I took my foot off the pedal to let it grab. That was her limit for sure.
I'd reccomend that off the batFinally have an on the books porting/custom fab business!
