What I am trying to solve:
2002 LX Sport rims on front of 1991 box without spacers
Ability to still use my 15" stock steelies
After a further 2 hours of research, I think I have figured out a solution. Please let me know if I got it right.
What I think I found out:
91 and 92-4 used the same calipers (from forum search)
91 and 92-94 used the same diameter of rotor, but of course different type (from forum search)
91 and 92-94 and some later is seems use the same lower ball joint (from Moog website and Orielly auto site)
91 and 92-94 used similar tie rod ends, at least the taper end that goes into the spindle (guessing since nobody complains of this one)
91 and 92-94 used similar sway bar mounting to the lower control arm, so the spindle should clear (guessing since nobody complains of this one)
What I think I can do to achieve my goal:
Use 92-94 upper control arms on my 91 box
Use 92-94 spindle, wheel bearing hub and caliper bracket on my 91 box
Get some new 92-94 rotors
Re-use my stock 91 calipers
Theoretically this will give me the bearing hub type front suspension and still have a small enough diameter brake to fit the 15's, while also letting me run my 17" rims without any spacers.
Thoughts?
Thoughts?
