Code of death, or Code 18 re-appears...
    I've been told its possible to remove the spider from the top of the distributor and then extract the PIP without messing with the gear. Never tried it myself.
    Failing that, the PIP is dead simple to change if you have a press with minimal risk of breaking stuff if you are careful.
    Cool, I will try that if I need to, but I wonder about changing the bearing or if it has too much play in it.
    I was able to find this: http://www.ebay.com/itm/-/311816009778 - Ford OEM TFI module. I ordered one and it came in a Motorcraft box and the module itself says Motorcraft on it. Seems legit.
      Originally posted by 89LincolnTWNcar View Post
      ...I always go with Ford/Motorcraft when I can, and from now on looks like I'll have to take my chances with junkyard stuff...
      This is how I roll. My experience with aftermarket stuff hasn't been great and seems the junkyard parts I salvage go further than aftermarket for less.
        Its just a bronze bushing in the distributor. If the bushing lets the shaft slop around I guess you could press it out and change it, but I've never had one that showed any real amount of movement. They get a lot of splash oil lube.
          Been two weeks and no problems yet. I just jinxed myself though by typing that... Also something I noticed after adding a couple grounds back to their factory locations the lights don't dim when I operate the locks or the turn signals as much at night. It is time for a lower intake gasket and front timing cover reseal job bigtime. Need to find a good condition timing cover because mine is fubar'd.
            Glad to hear it. Sounds like it's reliable again.
              Great news! I'm glad you stuck with it to the resolution was found.
                Good deal
                timing cover should be the same as a ton of things. I expect new ones to be available without any great difficulty.
                  Welp, now she has a dead cylinder, suspected bad injector. Anyone have a source for some new injectors or rebuilt used ones that aren't junk?
                    I have the 19# out of my car that were working fine when removed. I think they're 4 hole style too.
