Monty's 1989 CV LX
    That sux!!! I broke 1 of the 12 water pump bolts on my Ranger and was put out by that. When I was done crying, I removed the water pump, applied extra permatex to the area of the broken bolt, and stuck it back on there. No problems since. 4 though; like Bobcat said; you will want to easy out them.
      What's a good way to clean the timing cover and lower intake? Any type of chemical that I can soak them in for a while once they're off the engine? How about gasoline? I have to pump all that old fuel out of the tank anyway.
        What a fucker monty, sorry about the luck but douche that stuff with some Kroil or other penetrating lubricant and take another whack at it. I'm looking at doing a water pump, timing cover, and timing set soon. Not exactly looking forward to it. Hot as balls in SoCal summer. 108 last week. Yuck...
          I use degreaser in a spray can (gunk) and a pressure washer.
          Guess this makes a good time to check out the timing chain and gear?
            I have a slightly used double roller timing chain set from my old '88 on hand ... I ... think. Where did I put that? If I can find it, it will go on the '89.
              Valve covers, lower intake, and timing cover are off. Got the broken stud out of the block.
                looks pretty for the most part except that rear coolant passage... woof.
                  Yeah, that was the "dead end" coolant passage. A lot of goop in there.
                  What do you guys think of the small amount of slack on the timing chain? Enough to replace it or just leave it in there? I was surprised to find a double roller when I took the cover off. I'm assuming this engine was never opened before since the oil pan gasket was still the one piece that I had to cut.
                    New timing chain is in. Picked up some new coolant lines, but can't find the throttle body coolant lines at O'reilly's. Going to check NAPA tomorrow.
                      I'd just use fuel hose if no coolant hose can be found. little more spendy, but will probably be the last time it's ever changed.
                        Yep, 5/16 fuel hose is what I use for those coolant lines.
                          I don't think anyone lists 1/4 coolant line. I've also used fuel hose in the past.
                            Thanks, I'll give that a shot.
                            I got two of the three broken studs out of the timing cover. Third one won't budge. Even heated it with the torch. Drilled into it and I think I hit the threads, but it's not coming out. NAPA shows a new cover for $108. Guess I'll be ordering that tomorrow.
                              Bummer to hear the hardships Monty, but glad to see you anyway! If it's got tits, tires, or a trigger it'll give you problems. Having some stuck-screw issues on an old mauser I recently acquired too. Walked away but about to get back into it.
                                Walking away for a while is a good thing.
                                I just can't afford to spend $100+, right now, so I went at the broken stud again this morning. Drilled it out from the back side of the cover. Remembered that I have a tap and dye set. Tapped the hole and it actually worked. I even test fit the pump on the cover and it lines up.
                                The only problem I ran into is that I had broke the odd ball sized stud (circled in the pic below). No kit seems to come with this length and the AC bracket mounts to the stud. What I plan to do is buy another water pump stud kit, and take the longer stud, cut it down and use the dye to thread it. Just hope that works.
                                Edit: Didn't even have to buy another set. Two of the old long studs were still in decent shape. Dye cut one and it works. Victory!
