transmission gasket filter recommendation
    Originally posted by His Royal Ghostliness View Post
    Oh goodie, if that's the rubberized steel-core style those are pretty awesome, virtually impossible to overtighten the bolts with them and they don't try to squeeze out or even move around as you install them. Much better than any cheap aftermarket stuff you'll find at a parts store, so yeah go for that for sure.
    here is a link for a good aftermarket replacement of the factory gasket, same construction (steel core with bonded rubber) http://www.transmissionpartsusa.com/...-0027141hd.htm
    that gasket works on any AODE/4R70/4R75
    torque to 130 inch pounds for many leak free miles
      AWESOME! Just curious, would they have them for the AOD too?
      -1973 Volkswagen Bus Westy
      -1986 Honda Magna 700cc
      -2011 Subaru Outback
        there is no such gasket for an AOD, since the pan is made differently. for the AOD, I have good luck with the fiber/paper gasket (not cork or rubber) torque the bolts properly in this application also prevents leaks
