The car:
Stock internals and heads 351w with a duraspark, catted exhaust, and holley 4160.
What I've done so far:
Car was running pretty well until a wire broke in the distributor. Pulled distributor to put in a new magnetic pickup and pigtail. Upon putting distributor back in these symptoms started.
Checked firing order.
Checked plug condition
Replaced reluctor, magnetic pickup, duraspark ignition box, and coil (aftermarket pertronix with no resistor wire but it's exactly what I was running before. Also replaced battery and have had to recharge it twice during this process.
Checked all wiring between coil, distributor, and ignition box.
Checked that distributor is not 180 out.
Pulled front fuel bowl and metering block, cleaned, and replaced power valve.
Repeatedly moved around base timing, from way too advanced (idle rpm dropping from too advanced) to clearly too retarded.
Inspected for obvious vacuum leaks
Current symptoms:
I can eventually get it started with the timing waaaaaaaay retarded. Visually the distributor vacuum advance port is pointing dead straight or slightly to the drivers side instead of noticeable to the passengers, where it was at my previous tune before this all started.
Once started it runs like poo. How bad depends on how retarded the timing but if it's retarded enough to start it's retarded enough to idle noticeably poorly and at 500-650 in park.
I can get the idle up to where it was (1050-1100 in park) by adjusting idle while running. I do not know what this is in terms of base/initial timing as the engine dies immediately if you pull the vacuum cannister line. Even if you pinch it first (so it's not the vacuum leak killing it). The engine needs that much advance to run at all. Somewhere between 25 and 40 above base timing.
It will feel fairly smooth at idle even in gear once I get the timing just right, but will not rev up quickly and will pop back and died given load by footbraking/Brake torquing with significant throttle.
Once it dies, it will not restart at the ignition advance where it ran best. It will seem to fight the distributor hard like I have the timing way too advanced, fight it hard enough to almost completely stop the engine turning over. I.have to retard the timing by an obviously extreme degree to get it to start again.
Possible thoughts:
Clogged cat
Massive vacuum leak
Skipped timing chain
Burnt valve?
Demonic possession?
Cat stuck in Flux capacitor?
Current symptoms:
Possible thoughts:
Clogged cat
Massive vacuum leak
Burnt valve?
Demonic possession?
