Originally posted by His Royal Ghostliness
View Post
What Gear Ratio Should i go with.
Originally posted by BlackVic_P71 View PostSo the K rear is hard to find? I have mine sitting in the backyard...
I'd stick with getting the aero rear and have rear discs. Then get the appropriate gearing for the engine (GT40 HO) and the kind of driving that you do.
I made the mistake of not reading the entire suspension sticky when I was rebuilding the suspension in the CV. I grabbed a rear out of a '90 MGM; but there was still a '94 CV sitting near it that I should have snagged the rear from. By the time I read the entire sticky, it was too late, the car had been crushed.
Originally posted by Tiggie View Post4.10's with in OD = a 2.73 in drive.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Originally posted by nfldfordltd View PostSo about 2200 RPM @ 60 mph?
I've been searching for a k-code for ten years. I've seen maybe 100 boxes and none of them have had it. Found a 3.55 open (town car with trans cooler), and a 3.27 trac lok (town car again with sunroof). Other than that 95% all are 2.73/3.08, and 90% of those are open. I envy you all with k code wagons filling your pick n pulls.1990 Country Squire - weekend cruiser, next project
The one in my yard is the one off the wagon, swapped in a aero rear with discs and 4.10's so it's just sitting there. May need to rebuild and the drivers side drum was leaking.1989 Country Squire - Twilight Blue, 347 stroker
Originally posted by 86VickyLX View PostI found a K code 92 crown vic. That rear is sitting under my 86 now...The ones who accomplish true greatness, are the foolish who keep pressing onward.
1st thing I did even before swapping out the cassette player in highschool was trac-lok and 3.73's. They're perfect. Felt quicker but wasn't actually any quicker... There's just no cheating around a motor that runs out of steam before 4000rpm.
Would ofcourse spin them easier and most importantly spin both lol so it was worth it.Finally have an on the books porting/custom fab business!
My vote has been cast, 4.10's would be great...unless you are running a short tire then 3.73's. The nice thing about those gears and your specified highway speeds is that you won't have to downshift to pass on the highway. You can just barely roll the throttle and away you go. Fuel consumption isn't a big issue as I had concerns with my first set of steep gears years ago...gains in "city" driving and just a slight loss on the highway @70+ mph. People claim wild fuel economy losses after gear swaps because it's harder to keep your foot off the floorboard!'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
3.27Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
