change the drier if you open it up.
+1 on finding out what is on that tube. If it looks like sand, its the dessicant in the drier. If its black or metallic looking its probably the compressor grinding itself to bits.
Having restricted airflow on the evaporator and/or condensor can make this happen too. Run the interior fan on low and have a bad clutch fan and you'll get this problem.
