Official timeslip thread
This is a sticky topic.
    [EDIT]
    This thread is for track results only, documented or otherwise. If you've got a comment on something you see here, post it there:
    Commentary on the official timeslip thread
    In an effort to keep this organized, any banter posted in this thread will be deleted. Please post your comments in the "commentary" thread.
    Thank you for your cooperation.
    - Hwy
    [/EDIT]
    (not sure if this is the best forum for this, but did not really seam to fit anywhere else)
    Post up you best time. Be prepared to show proof if someone calls BS.
    My best so far is a 15.98 @ 90 with horrible traction.
    Engine Info can be found in Here
    suspension:
    Front: police coils with 1/2 coil removed. Carrera Street Stock shocks, Wagon sway bar, ENS endlinks.
    Rear: cheap Gabriel shocks, "EE" springs.
    Weight mods: No sound deadening, no insulation in the body, no back seat, No HVAC ducting, no carpet in trunk.
    Battery relocated to trunk. 16 Gal. fuel cell in the trunk with stock tank removed.
    *EDIT* new best for the 1/8th. 9.5 @ 74 thats good for a 14.8 1/4. Mods different from above are. 325/50R15 BFG Drag Radials, New carb, althought it is the same as the previous carb, still needs to be tuned. And 15deg of base timing, had 9 before.
    *edit#2*
    This is a few months old, but 13.37 @99, thats with the GT-40 heads, a passenger, and the nitrous turning off 1000rpm early.
    Competition engineering 90/10 shocks, stock sedan coils, no front sway bar. consistent 1.9X 60's except when i tried to spray out of the hole and went sideways.
    15.7461 @ 87.43mph, Car is not running well, but honestly I don't think it is effecting the 1/4 mile times.
      14.86@92.5 mph was the best for the 87, with all the HO cam and heads
      16.03 was the best with the lopo heads and cam.
      Vids of the 87 here: http://www.grandmarq.net/forum/viewtopic.php?t=3893
      The 87 had:
      3.73's
      Traction Lock
      Removed A/C condensor and lines
      Removed air pump
      110lph mustang fuel pump
      MAC equal length shorties
      2.5" exhaust with Edelbrock RPM mufflers
      PI rear sway bar
      PI/Towing Package brakes
      Moog HD springs
      Gabriel HD/Taxi shocks
      HO Throttle body, upper intake
      19 lb injectors
      86 Mustang HO ECM
      Electric fan
      Mildly ported 79 302 heads (no emissions bump)
      92 HO cam
      Ported stock EGR
      EGR coolant lines removed
      180* thermostat
      3/8" phenolic spacer
      15-18* of base timing
      Dynoed 195.6HP on 87 octane with 10* base timing.
      [/url]
        16.05 @87.15mph
          I had my first taste of drag racing at Englishtown this year. It was pretty fun. It was a free event sponsored by the JDM guys.
          Best time of the day: 15.771 @ 86.96 mph
          I think I can squeeze a little more out of it if I softened up the rear. I left my car setup for autocrossing. I was so psyched to race that I forgot that I could adjust the shocks and tire pressure. I didn't do any burnouts either because I was planning on doing more autocrossing on the same tires.
          I'll give it a few more tries next year but I don't think I can squeeze out any more without any major engine work. I might go somewhere for a dyno tune.
          2001 Grand Marquis LS
          SuperMotors Page
          CJMF
          Motorsports North East
          Best 1/4 Mile : 15.771 @ 86.96 mph 11/05/05
          224 RWHP - 250 RWTQ - 03-18-06
          New Best 1/4 Mile :
          15.195 @ 89.79 mph 2.207 60' 11/03/06 - Race weight 4458 lbs.
            Mods: Procharger air-to-air intercooled P1-SC @ 9 psi, Walboro fuel pump, 39 lb injectors, 4.10 gears, 3k stall t/c, Cobra manifolds w/ x-pipe and Magnaflows.
            Supercharged '03 Mercury Marauder - SOLD
              USLYDAWG's 81 Colony Park
              This is the 14.18
              speed is off.....................................only 94mph................should be 96mph
              60ft time is 2.031
              9.047 at 1/2 track altho the speed is off slightly to a 77.58
              Final et is 14.18 at 94.97 mph
              FORD crate Explorer short block 302ci
              CRANE hydraulic flat tappet cam with specs similar to COMP CAMS XE268 only 114* lobe centers for a smooth idle and streetability
              DO 351 heads gasket matched
              C4 trans with 2500 converter
              456 gears
              4180# with driver
              stock suspension
              driven in, raced all weekend, driven home.
              This time slip was NMRA March of 04 2nd time pass.
                This is what i did with Stage II setup
                03
                r/t-.905
                60'- 1.832
                330 -5.085
                1/8 -7.804
                mph -89.71
                1000 -10.181
                1/4 -12.187
                mph -112.94
                I am now at Stage IV .I had the motor raced prepped to cobra specs and heads freshened up.well i only put about 3k on it and blew 2 pistions when i took it to the track to get a good time on it.as you can see from the timeslip what happened to it.
                http://www.mercurymarauder.net/forum...3&d=1131764433
                Well i'm still waiting for the new motor(#3) to come back with ported heads(this time) and fuckin pray this shit doesn't happen again.But i dont think i'll be able to post a time slip as tracks for me are taboo and wifey says stay AWAY!!!!Heh he....
                  You supercharged marauder guys are the kings of the panther world
                    Well at SF06 I went down the track a staggering 2 times...and didn't make any real improvement over the last time I was at a strip, and this time I have a tricked out wide ratio transmission. Scott was sayin the elevation was probably the reason, I am getting the feeling my car is just gettin old.
                    But with my fastest 1/4et time yet, I have my slowest trap speed yet...
                    15.7185 @ 86.67
                      i ran my best time yet!
                      15.94@ 87.89 mph
                        According to my explorist 600 GPS unit, the elevation was ~960ft above sea level. The temps were at least 80º, which im willing to bet was quite a bit warmer than your last times from November
                        '80 Town Coupé
                          Actually, though it was November is was pretty warm when I last went.
                            15.7185 @ 86.67
                            if the times are close normally the lower e.t. will have the lower trap speed. since you get to the line sooner you have less time to accelerate. Watch some professional drag racing, something like pro-stock everyone is pretty much within .01 seconds of each other, the guy with the slower e.t. almost always traps higher.
                              Changes from last time are cowl hood and 14" air cleaner. picked up 2/10s in the 1/8 with it.
                              R/T .144
                              60' 1.986
                              1/8 8.994
                              mph 75.98
                              prety good run, still some tire spin but not much, car ran strong.
                              thats about a 14.0 @94 in the 1/4
