Hello,
I had to avoid two idiots and their roadrage yesterday and slammed my right rear wheel into a curb.
I have a leaking real seal and hopefully only a ruined bearing.
I had to drill and chisel the rim off. The lock key broke. I bought a lock nut removal socket that did not help. I put the spare rim on and get a wobble (not lateral) in the rotation.
The wheel does not spin easily and I feel a wobble of some type as I drive.
I may have someone else do the work because we are back into the upper 90s.
If I do it myself, how difficult would it be?
Also will need help getting the other 3 rims off at some point.
It is a 90 Colony Park.
Thank you,
Mike
Thank you,
Mike
