Over the summer my blower on my 91 CV would sometimes work & sometimes not. Worked on all settings than only on high than it stopped working all together. So I researched the threads & replaced the Blower Resistor & pigtail. (Both were toast) But it still wont work.. Check the fuse it all good. Next step would be the blower itself or is there anything else I should be looking for????
blower on hvac not working
91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpicTags: None
Something that worked for me in my 2000 MGM for a similar problem was cleaning the contacts on the motor. They were black, and it's been fine since. For a 1991, a new motor might be in order.
I would test the blower in place by connecting it to the battery. It'll spin or it won't. If it spins... probably the fan switch has issues (possible harness as well). If it doesn't spin... there's your problem.
yep, power the blower direct and see if she goes.86 Lincoln Town Car (Galactica).
My 91 had that problem and it was the blower resistor assy that had toasted.Finally have an on the books porting/custom fab business!
