My 1994 Crown Victoria
    Just had the fuel pump relay replaced. Car was having intermittent starting/running issues. I hope it will be reliable now! Next plans: undercoating and get a set of winter tires.
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
      Good show!
      1997 Crown Vic - Mostly rust free, moderate mileage. On the road... but far from perfect. **SOLD**
      1985 Crown Vic in 2-Tone Blue **SOLD**
      http://automophiliac.blogspot.ca/
        Sony tape deck issue
        The nob works and the display window lights up but there's no radio function. Pressing the buttons does nothing...
        '94 Crown Victoria
          Check the wiring, if that's ok, then put the original radio back in!
          Works for me every time!
            undercoating
            Got the undercoating done today. Next up: find a set of winter tires. Might get a used set off Kijiji to save a few bucks.
            '94 Crown Victoria
              Nice car. Some 'Zout' or similar would do wonders for the stained carpet. My 2000 GM was a real mess and that stuff helped a lot.
              David
              1989 LTD Crown Victoria LX
              14 previous Panthers, gone but not forgotten....
                Back in service!
                The shift tube broke last month, shortly before Christmas...I had my car towed to a transmission shop who verified the problem but they didn't want to do the work So I had to get my car towed AGAIN. I had the Ford dealership do the repair. After all was said and done, the bill was almost $400 but now the shifter works perfectly!! Fingers crossed that there won't be anymore repairs needed for awhile.
                '94 Crown Victoria
                  It's been a while!
                  I bought a new gas tank and straps back in April. Got a shop to install the parts last week. Inspection is due next month and it should pass. The heater core still needs to be replaced. Planning to have that done by the end of the year...
                  '94 Crown Victoria
                    Failed inspection because of the front cross-member and a small section of frame on the passenger side. I'll get repair qoutes...I would like to get a few more years service out of this car.
                    '94 Crown Victoria
                      It was a good day!
                      The frame and cross-member have been repaired. Old metal has been cut out and new metal has been welded in. Was undercoated after. Set me back $460 after tax. Scored a heater core tonight for $20: https://www.kijiji.ca/v-engines-and-...box/1302437975
                      Will have it installed within the next few days
                      '94 Crown Victoria
                        frame pics
                        Before and after: Click image for larger version
ID:	1282436Click image for larger version
ID:	1282437Click image for larger version
ID:	1282438Click image for larger version
                        '94 Crown Victoria
                          Nice! But a lot of work. Decent price for the amount of labor though. Where I'm at, it would be at least double that price.
                            May she live on!
                              I think I'd be looking into the internal frame rail rust converter stuff. Eastwood sells one, basically its a spray can with a long-ass tube you shove down through an opening and it coats the inside. Maybe not perfect but its better than nothing.
                                Man, that rot was pretty advanced. That is actually worse than my Town Car, though the hole in pretty much the same spot on the torque box is getting rather large. I'm not sure I've ever seen the trans crossmember rot away like that on an Aero/Whale, seen lots of boxes do that tho. I may see if I can get a shop to fix my frame, but the rest of the car is rough enough that I'm not sure I want to sink the $$ into it which is why I replaced the car already, but it just won't die.
                                -Steve
