My 2004 Ford Crown Victoria LX
    So i needed to find another vehicle for the winter as my buick's engine seized(oil pump stopped making pressure, no idiot lights came on my dad said), so been on the hunt for another panther came across this gem at a used car lot for $500. It is a 2004 Ford Crown Victoria LX loaded with every option besides heated mirrors and a sunroof. Car has 240,000 miles but runs decently, trans has a odd issue where if put into Overdrive it will shift into overdrive around 30mph which i think is to early and then neutral out around 45mph, if i turn off overdrive car shifts fine with 3 gears and still gets decent gas mileage. i have plans for this car down the road as i fell in love with my first whale panther. Her name is Valerie.
ID:	1303646Click image for larger version
ID:	1303647Click image for larger version
ID:	1303648Click image for larger version
ID:	1303649Click image for larger version
ID:	1303650Click image for larger version
    Sounds like you're getting torque converter lockup in 3 at 30 mph, and the OD band is smoked which is why it neutrals at 45.
    For 500 bucks you done real good. Find a low mileage junkyard trans and throw it together.
      Cool. Nice find Matt. Good luck with it.
        I plan to get another trans and another motor, this motor has the common issue 4.6 SOHC motors have the dreaded timing chain guides, there going rattles alot, i would replace it with the full timing kit but it cost $250 on rockauto for it, instead of that i can get a Mark VIII 32V 4.6 swap for that kind of money. There is a 97 mark viii in my local yard im tempted to yank its engine along with its ECM and engine harness. I have sourced already a Marauder Intake for $75. But since the car runs i will just get this new engine all set up until im ready to swap it over.
          $500 looks like a deal. On a car lot! I guess they were going to auction it so $500 is a good deal for them too.
            The Marauder intake won't work with the Mark VIII motor. B heads vs C heads. However, a steal for 500 bucks!
              So unfortunately the engine blew up last week on I476 heading to johns house(1 hour away from my house, oil pressure light came on and lots of chattering seized the engine, so now i will be swapping the engine over the winter. Donor vehicle will be a 2009 Ford Crown Victoria P71 Engine, mileage unknown(speedo was missing), but is intact and looks by far the cleanest 4.6 i have come across. Cranks spins decently on it and it has compression, it was last on the road in 2014. i suspect the engine to be ok as the car was in a front end crash which is why it went to the junkyard. stay tuned.
                I thought all the timing chain guide issues were over and done with by '04 (iirc '03 should be last bad years). Anyway, great find, hope the engine swap goes well and you get many years of service out of her. Just remember: NO SPINNING TIRES IN THE FUCKING GRAVEL.*
                *Unless it's your property, your gravel, and no one is anywhere behind you, also, "you'll chip your fenders, kid"
                  Time for an update. The new engine was put it January 22, 2017, Putting in a 03+ 4.6 is much easier than a 5.0 302, went in less than a day, car runs beautifully. here are pics i took during the process. Shortly after the car was road i went to the junkyard with 86VickyLX and scored 3 2005-2009 Mustang V6 Rims, put them on the car looks aggressive. 4th wheel is on its way from ebay and will be put on at the end of the week.
                    more pics
                      more pics
                        even more pics
                          and the car in its current state
                            Lookin good there Matt.
                              Those wheels look really good on there.
                              Wondering what caused the carnage with the rods. Did a rod bolt snap?
