Curious Vibration While Coasting
    My 2000 MGM developed a curious vibration after an unintended "neutral drop" in a parking lot. I messed up my initial reverse from a parking spot just as someone else came along. After seeing this person was going to wait for me rather than go a different route, I went to put it in Drive to move forward, but the gear didn't engage. (I'm guessing the steering column could use new bushings.) I was feeling pressured from the other person waiting (it was one of those days), and as it happened, I ended up putting it into Reverse while the RPMs were up, though not too much. I heard a "bang" just before the left rear wheel spun (because it was wet; no trac lok).
    I didn't notice anything the first time I went on the highway just after that. But while on a long trip during the wee hours with the cruise control on, I could feel a curious vibration in what I presume was the rear end while the car was coasting. The only thing that came to mind is some kind of damage to the reverse side of the diff gears, since driving forward under power is still smooth. The same problem was still there without cruise control on. I don't notice anything with city driving or reversing.
    Is there some kind of obvious part or interface that might have got jostled or something? The only other thing I can think of is knocking off enough rust from the driveshaft to unbalance it, but that wouldn't seem to explain why the problem only shows up while coasting on the highway.
    At 175k miles you're kinda due for inspections and likely rebuild - I've seen 8.8 axles with less miles that have their carriers slide sideways under load cause bearings wore out. A pattern check on the gears will tell you if the coast side is meshing looser/tighter than the drive side, but even so it should not cause a vibration - humming maybe, but no vibrations. Also typically the U-joints are a whole lot easier to damage with shock loads than gears are. I say start by dropping the driveshaft and checking the U-joints for play and/or stiffness. Go from there.
      I support the message of checking the U-joints, simple things first. Ashley's TC had a weird vibration above certain speeds and that's what it turned out to be.
        yeah, U joints would also be my first guess. Not uncommon for them to get goofy and act up only loaded in one direction.
          I don’t know much about U-joints yet, but it’s nice to know it might be something relatively simple. From what I’ve read about diff internals, that’s really not something I’d ever want to mess around with. (It’s still under 122,000 miles btw. ) I won’t be doing much driving over the winter (especially while worried about my timing chain tensioner stuff), so at least I can put it off until the spring. Many thanks for your input!!
            Pulling the axles for inspection is actually really simple. Outer bearings and seals are also easy. Those are really the only parts that typically wear. Where you get into fussy stuff is when you remove the carrier and change the gearing.
              Wouldn't even mess with the axle guts at this point, mileage is low enough (I saw the 175k but missed the KM behind that) to where there shouldn't be any issues inside yet. Stick with the U-joints for now, four 12-point 12-mm bolts hold the shaft to the axle - remove these and the driveshaft will easily slide out of the transmission tail-housing (may wanna have the car nose down ass up for this so fluid flows towards the front and doesn't leak out the rear hole when you pull the shaft out). Then you can wiggle the U-joints by hand, you should be able to feel which one is seizing up (feels very notchy/bumpy) or wearing out (feels very loose, even flops around with the sound of cow bell in more extreme cases), what you want is tight but smooth motion that doesn't require a lot of force. Replace as needed.
                I'll be planning on changing both just to be done with it. With any luck, I'll be able to get an aluminum driveshaft to avoid rust issues in the future. Apparently I would only need to swap in my slip yoke on the front end and get the Fabtech spacer for the back end.
                  U-joints!
                    It looks like the problem has largely resolved itself all on its own, though replacing the U-joints (preferably while swapping in an aluminum driveshaft) is still on my list of eventualities.
                      I actually strongly dislike such self-resolving problems - mostly cause then I don't know if whatever was causing them has truly gone away for good, or is just lurking in there gathering strength and waiting for the right moment to come back with a vengeance. Therefore I suggest you still pull the shaft and inspect the joints, or you may be risking doing a transmission output shaft bushing and/or pinion seal well before you're ready for the aluminum shaft upgrade.
                        This, totally. Shit that "fixes" itself has come back to kick me in the balls more times than not. Had some valvetrain noise in my HO that went away then killed my oil pressure when all the needle bearings from one of the roller lifters lodges themselves in various parts of the engine. Not cool.
                          Meh lost first year in the 88 for two weeks. Then it came back. That was 45k miles ago. Sometimes self healing is good.
                            Junk in the valve body is one thing. Loose/binding U-joints are completely different, especially once you get them spinning above 2000 RPMs. Heck I just replaced a pair of U-joints that run $50 a piece, and those shafts turn at quarter of the main driveline speed. High-speed rotational vibrations are not to be taken lightly, lots of shit can get damaged by it, not cheap to fix shit either.
                              Yeah, good point. I was planning on crawling under my car for other stuff on Friday, so that would be the ideal time to check them. Are there special lube considerations for the slip yoke and seal? With non-automotive basic seals I've worked with in the past, I was told to put grease between the two lips. I know for the harmonic balancer seal, you're supposed to lube it when installing, but is it self-lubing after that? The one I got has a patterned surface on the inner lip, which I'm guessing is to allow oil to get in. For the slip yoke, I read something recently about some kind of special grease for the splines, but would that only be for an initial installation?
