Curious Vibration While Coasting
    Slip yoke splines need no grease, they will flood with transmission fluid quickly enough after you fire up the engine.
    Yes do use some grease on the seal between the two lips, really doesn't matter what kind it is as it's there just to make things slippery and all grease dissolves into transmission fluid eventually anyways.
      Just don't go nuts with the grease. You only need enough there to keep it slippery until a bit of trans oil works its way in there to keep it moving.
        I pulled the driveshaft last Friday and the U-joints seemed fine enough. They all had a full range of smooth movement with no hint of binding etc. There was at least one axis on one U-joint that had noticeably freer movement than others (I didn't keep track, but I'm pretty sure it was on the front end), but there wasn't any slop in it. My drive afterwards felt pretty much the same as after the problem largely corrected itself. By "largely" I mean I think I can detect a very brief and small amount of the curious vibration during transitions between powered and coasting movement, but I might be imagining things.
        Just before the problem largely corrected itself, my car had been sitting for many days, and the battery had been disconnected for some of those days (as a result of going to check my plugs and change boots before deciding to put it off until I do the tensioner stuff). I can’t imagine that there’s a computer aspect to the curious vibration, but I’m far from being an expert.
        FWIW, I don’t know how the pry bar on the diff end of the driveshaft trick is supposed to work, but what I ended up doing is putting two pry bars back to back so they served as each other’s fulcrum and then squeezed them together. It worked like a charm.
          WTF are you talking about? Xplain yoself pleez!
            I just picked a random photo from the internet (apparently from another type of car, ignore the arrows) to show the square slot (seen at the bottom) where people say to use a pry bar:
            I used two pry bars:
ID:	1280949Click image for larger version
              Oh THAT, to pop the yoke off the companion flange. Yeah that don't really work when there's good amount of rust involved, somewhat more violent measures need taken to make things separate then But typically a few good whacks with a dead-blow hammer or even a rubber mallet is enough even with mild case of rust and is obviously pretty safe, whereas your trick with the two prybars can be quite dangerous if something slips. Just keep that in mind for next time you gotta work on something like that.
                In my case, I was laying on the ground and just used my abdomen to catch it. It didn't really take much (after some light tapping didn't work), and that was the big surprise for me. I cleaned and oiled the mating surfaces, so hopefully it won't be an issue next time. I suppose a good precaution for stubborn ones would be to put loose zip ties through the bolt holes so the yolk doesn't have anywhere to go when it pops free.
                  How do the needle bearings in the U-joints work? Do they engage in a constant rotation when the yoke spins, or is it just a back and forth motion like a throttle plate bearing?
                  Edit: Here's a neat video:
                  My impression is the pair for the left shaft in the video might just go back and forth but the pair for the right shaft in the video might have a constant rotation in one direction. I can't quite visualize the latter.
                  My impression for my issue is that there's a transition zone from driven to coasting, and that the vibration occurs as a result of some slippage in the transition zone. I'm not sure if that actually makes sense in terms of how the needle bearings are supposed to respond.
                    They do whatever they feel like doing - change the grease consistency even and you change their behavior. You're overthinking this, if they got play replace the fuckers, use a quality U-joint - tight U-joints make no clunking noise, and I've had high-mileage factory Spicers move nicer than brand new Moogs. That said do keep in mind the 8.8 axle is one of the loosest ones out there as far as gear mesh goes, for example a Dana 60 (front or rear doesn't matter) calls for 4-9 thou backlash whereas the 8.8 wants 11-16 thou (yes I know the numbers by heart, lol), a 5-thou Dana will always be quiet whereas a 15-thou 8.8 is one hell of a clunking mother! The right gear man will make your axle do pretty much what you want it to do, but you'll pay for it (last one that needed special attention took me a whole night). Keep in mind that a noise-maker most people won't think of can be the axle shafts sliding in-out excessively, that was what that all-nighter was all about actually.
                      I watched Eric The Car Guy rebuild an 8.8 and said F that. You guys that have the patience for that, good on ya.
                        My '97 has a lot of backlash. At least I think thats its issue. Get the typical clunk when going from coasting to not coasting that originally I thought was u-oints till I changed them. There is noticeable amount of rotational play in the pinion, but nothing up/down/side/side. Doesn't leak, and doesn't seem to effect anything. There is a distinct driveline vibration in it too. Slight whine at some speeds. I attribute a lot of the whine to it not having oil in it when I bought the car. The diff was dry and not making any noise when I got it so I never checked the oil. Then after I'd put around 10k miles on it, it ate an axle bearing. When I opened up the cover, much to my surprise, about a pint of very dark "oil" came out. Ring, pinion, and side gears all looked remarkably good considering the "abuse". Changed both axle bearings, filled it up, and drained and refilled with fresh oil again 1k miles later and what came out was clean with a hint of metal. Filled it back up again and called that good enough. Its been chugging along like that for 50k miles since all that. Still whines slightly most noticeably from 45-50mph, I've had passengers never notice it, but I do. I was considering a junkyard axle swap, one of the local yards had 3 sub-100k 3.08 Town Car axles to choose from for $150-$200, but I chose to just live with it since its working fine.
                        I notice the 3.27 axle in my '98 HPP has the same whine at the same speeds but quieter, which I didn't notice when I test drove it because I've learned to tune it out. When the weather warms up, I'm going to service that diff, as well as throw new u-joints at it since my Town Car u-joints at 90k were past it. Cheap insurance that I'm not unknowingly damaging it IMO.
                        -Steve
                          I've heard that throwing a strong magnet on the cover can help with some of that.
                            ... You're overthinking this, if they got play replace the fuckers, use a quality U-joint - tight U-joints make no clunking noise, ...
                            U-joint related play and clunking aren't issues. I'm getting a bit of funny vibration during the transition from powered to coasting movement, but only at highway speed. I would guess that the one axis that had freer movement (but without slop) is the culprit, and I'll find out soon enough; but in the absence of an emergency, I’m not climbing under my car again until the weather warms up. What’s wrong with wanting to learn how things work in the meantime? I’d love to be able to spend some more time learning more about the Riemann hypothesis, but there doesn’t seem to be much chance of that being productive until my eyes are finally fixed.
                            I turns out that the hybrid U-joints aren't astronomically priced like I thought they would be (as a 'specialty part'), so I'll probably go for whatever decent CVPI aluminum driveshaft comes my way rather than hope for an older one that uses 1330s. I should be able to get price-matching on Spicers (at least the 1330s) at a local place. I would want to be able to use the driveshaft in something else when my current car reaches the end of its life, so I won't cheap out on those.
                              The needle bearings rotate maybe 1/4 turn at most. The less they have to move, the better your shaft alignment is.
                                I played the video at its slowest speed to clarify the movement of the pair of bearings for the right shaft. I was thinking in terms of whether microscopic people inside the bearings would always see the needles moving back and forth or whether they might actually see the needles moving in only one direction at any point, and it looks like it would be the former.
