Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 361 to 380 of 400
Thread: Buyer's Remorse (AKA "Hideous") - Giraffe's 1990 Grand Marquis LS
  1. #361
    GMN Regular Giraffe's Avatar
    Jan 2016
    Cabot, AR
    876
    Nice. I recently picked up a milwaukee M12 (1/2") stubby impact gun. Bunch of torque settings and very very impressive. Does lug nuts better than my ryobi 18v impact.
    Anyways for more accurate toe readings (for anyone planning to do this as part of their real alignment) you kinda have to roll the car back and forth after you make an adjustment. The suspension does not settle fully, nore do the tires if you just drop it. My Vic is self aligned by me in my backyard. Took way to damn long setting caster, camber and toe but it can all be done.
    Curious, did the taillight lenses need a clear? A sand up to 2000/3000 and some plastic polish would not give you a good result without the potential for clear fading?
    I made sure to back it up and drive forward after setting it down and before measuring. No problems there.
    On the tails, I was going off a procedure from a highly experienced paint and body guy on the Mustang forum. I do beet to wet sand the clear to knock down the orange peel a bit. I have to buy some 2000 grit paper first, though. Will update that when done.
    óJohn
    1990 Mercury Grand Marquis LS (POTM March 2017 & May 2019)
  2. #362
    Sep 2008
    Whitestone, NY
    19,221
    Cool. Ive heard mixed reviews (based off of headlights being clearcoated) enough so that I don't intend to ever do it to my own. If I have to go back every year for a polish I will take that over stripping off old clearcoat. I will say that when done correctly clearcoated lights do look damn nice.
  3. #363
    Sep 2014
    Warren, MI
    5,932
    I think it is possible to love your tools. I've got a 1/2 inch DeWilt electric impact and if it wasn't for the drill-esq direction buttons (too easy for your thumb to slide into and change the direction without realizing it), I'd love it. The middle torque setting tightens right up to 100ft lbs, right on the nose for my K1500. First real power tool I've bought and it's a game changer, no more tightening lug nuts by hand. When Ashley had her F250, that was a PITA, 32 lug nuts by hand...
  4. #364
    Jan 2016
    Cabot, AR
    876
    Well, the two people I know who get excellent results with clear are both highly skilled paint and body guys. If these lights end up looking like crap because I'm not, I'll probably just send them to one of them.
    I installed all new springs and shocks on my car before I had the impact or even an air compressor. First time I had ever had those wheels off myself. I about killed myself just loosening the lug nuts. Nothing beats having the right tools!
    I would to get a 1/2 impact as well in the future. That would also make a nice junkyard tool.
    óJohn
  5. #365
    Sep 2014
    Warren, MI
    5,932
    It does certainly come in handy at yards, zipping things like differential covers off takes seconds, not minutes. I still find myself going to hand tools out of habit though. Plus with how bulky the damn thing is I need more u-joints and extensions if I want to use it in hard to reach areas..
  6. #366
    Jan 2016
    Cabot, AR
    876
    I had thought about the bulkiness of it. As soon as the tax return comes in I'll be purchasing this to go along with it.
    óJohn
  7. #367
    Sep 2014
    Warren, MI
    5,932
    Oh wow, I need that and a 3/8th drive impact.
  8. #368
    Jan 2016
    Cabot, AR
    876
    I may have a problem. I removed my upper intake since I realized at least one bolt for the lower needed to be retorqued. When I removed the throttle cable bracket, I realized that both tabs on the TV cable are broken. There’s nothing holding it in the bracket. Is there enough tension for it to be fine, or am I going to need to figure out something to keep it tight against the bracket?
    óJohn
  9. #369
    Mar 2010
    Lewisville, TX
    21,649
    When it's mounted, it should seat in the hold and stay put. Unless there's a condition in the cable that causes it to stick when the throttle is released and push it back out, but that would just make the pressure stay high and hold the gear. This wouldn't damage the trans, but just keep you from shifting properly. One idea I just had to possibly make a temporary (that will be permanent) fix would be to use one of those VSS retainer clips to bolt the cable down to the bracket.
  10. #370
    Jan 2016
    Cabot, AR
    876
    I ended up grabbing an extra bracket I had laying around. This was a bracket for a seat belt/head lamp buzzer. I hammered down one end to make it straight, cut off the excess, and used an existing hole in the throttle bracket to secure it using a flanged bolt from my stash and a nylock nut. I think it was successful. Car drove fine earlier this evening.
    I secured it using the only Snap-On tool I currently own. I don't remember where I acquired this 10mm wrench. I have almost ten of them.
    It isn't seated 100%, but I don't think it's enough to make a difference.
    óJohn
  11. #371
    Member
    Feb 2019
    Windsor, CT
    40
    Looks good!
  12. #372
    Mar 2010
    Lewisville, TX
    21,649
    Good enough. It just needs to stay generally in the hole. Since the lever pulls on that cable, it'll stop once it seats fully. The return spring usually keeps the cable tight enough to keep the cable from removing itself from the mount anyhow. But now it won't go anywhere for sure.
  13. #373
    Sep 2008
    Whitestone, NY
    19,221
    I approve.
    Nice work. I would have done the same thing. In those "oh fuck" moments I always try to come up with a quick fix.
  14. #374
    Jan 2016
    Cabot, AR
    876
    Any idea what might be causing this? Found this after I drove the car today. Smells vaguely of gasoline. I don't think it's coolant.
    óJohn
  15. #375
    Mar 2010
    Lewisville, TX
    21,649
    pull the dipstick and check that. If it's all milky... something is very wrong. If it's got a stain, but the oil itself looks fine... you may have excessive condensation buildup in the engine and need a good hour drive to bake it all off.
  16. #376
    Sep 2014
    Warren, MI
    5,932
    Mmm forbidden guacamole...
  17. #377
    Jan 2016
    Cabot, AR
    876
    Oil looked clean, but had the same film on it.
ID:	51673 Click image for larger version.
    óJohn
  18. #378
    I post a lot...
    Mar 2007
    North Las Vegas Nevada
    2,371
    Looks like what Sly said condensation in the engine.
  19. #379
    Mar 2010
    Lewisville, TX
    21,649
    Yeah... oil looks good. I wouldn't worry about it. Just be sure to give it a good run some day... get it up to operating temp for a good 30 minutes. It'll bake all that crap out.
  20. #380
    Jan 2016
    Cabot, AR
    876
    Inching ever closer to the big brake swap. Upper control arms are assembled with poly bushings and ready to go.
    óJohn
