Buyer's Remorse (AKA "Hideous") - Giraffe's 1990 Grand Marquis LS
    Excellent work. I would dread performing that task while engine still installed. You have some good patience.
    One can go gasket-less between the egr spacer and throttle body if you are not using the egr coolant ports. Would just need to cap off the two ports so the idle wouldn't raise up because of that potential vacuum leak.
    The stock egr spacer also has a little "moat" so to speak that can handle a little bit of coolant if it so happens to escape the gaskets walls and route it either out the top corner or bottom corner between the egr spacer and throttle body. I forget which one to be exact.
    A common practice after boring out a stock panther egr spacer is to place some JB weld into whats left of that moat....which is now basically a vacuum leak in and of itself because the boring process takes away one side of the moat. You have a direct path from the outside to the intake if it is not somehow blocked off.
    It also helps to put the JB weld in there after a bore job so coolant does not enter and drip into the intake as well.
      Trick with the "moat" is that it only works if the drain hole isn't blocked up, which it probably would be with RTV.
      Last spacer I bored out, I faced it off so that there was no groove. There wasn't enough metal left for it to have had any chance of sealing, and it was easier to just shave the spacer and get rid of it entirely. Its not that deep, maybe about .030.
        Great job. Fun task but rewarding when oil leaks are gone
        -Nick M.
        Columbia, SC
          That is a good idea.
            That block drain plug is going to seize now without all that oil keeping the rust away.
              There's still so much oil and grime on my beater from the VC and lower intake leaks... it'll take years for all of that to come off.
              Also, that was all of the leaks (save the power steering pump and that is minimal).
                Have you tried Gunk?
                1993 Ford F-150 Flareside - July 2010 - August 2013
                2004 Ford Mustang - September 2013 - February 2018
                1987 Mercury Colony Park GS - August 2015 - Present
                2018 VW Golf GTI - February 2018-February 2021 (was a lease)
                2003 EZGO TXT - March 2015 - May 2019 (it's road legal!)
                2019 VW Golf Alltrack company provided April 2019 - Present
                2012 Fiat 500 5 speed - January 2021-Present
                2003 Audi A6 Allroad 6 speed July 2021-Present
                  A lot of times you can tell if it's got the JBL stuff by looking at the speaker grilles; JBL stuff will have a "Ford JBL" logo that faces the rear window whereas the standard stuff will have "Premium Sound" on them. That's always my tip off, I think Mark VII's also have a cover over the amp & rear speakers. You'll most certainly want the rear JBL 6x9's, those are hard to beat soundwise without spending considerable money. You'll have to take the four screws off the top to get at the tweeter & midrange speaker wiring to disable the mid range as they have foam surrounds which will most likely have disintegrated by now. Rest of it will work great, especially the bass.
                  Check your car first though, I think on CV's & GM's the premium sound amplifier lives in the trunk just behind the driver's side rear speaker. Show us some pics so we can verify what you've got.
                  My front speaker grilles just say "STEREO" on them, and my door tag says I have standard cassette sound. Is there any way to upgrade to the Mark VII JBL stuff without premium sound already installed? I assume it is no longer plug and play.
                  It wasn't that bad this time around. I just took my time and tried to be patient with things. I parked the car over a clean spot in the driveway yesterday and still didn't see any leaks. Very happy with the results. I may go ahead and get rid of the EGR coolant passages. My '95 Mustang doesn't have that stuff; I can't imagine that it would really heat soak the intake charge so bad that the coolant would be necessary.
                  Very fun!
                  Someday I'll pull the car off the frame and clean it really well when I own a lift and a power washer.
                  —John
                  1985 Ford F-150 XLT Lariat
                    Pics please.
                    If you've got speakers in the door that says to me you've got the premium set up. Come to think of it, all of the speakers will have "premium sound" on the magnet if so, or unless someone swapped them out before. My 85 had factory base radio and were devoid of any markings.
                    You are correct; If you don't have the premium sound already on board it's no longer a plug & play type of deal. Maybe you do though, post pics of that rear trunk shelf area. Even if you have the silver football garbage (I've seen some later cars with it...) I have the JBL amp that might work with those connectors.
                      Pics please.
                      This is a '90. There are speakers in the door because they did away with the dash speakers in '90. What he has is not premium sound (unless someone swapped the speaker pods out for some reason), the same as what The Ice Car has where the speaker pods on the door say stereo instead of premium sound like the ones in The Scab.
                        Everything is possible, it just gets more complicated if there isn't an amp in the trunk already. You'd need the donor wiring harness out of another car though.
                        Or you just put in a better radio and don't worry about it. At some point it stops making sense to be installing 25+ year old amplifiers that have parts which cannot be replaced and speakers made of paper that have been baked in the sun for decades.
                          I get what you're saying. I'm thinking I may just get some good aftermarket speakers that fit in the stock locations and get a good head unit to complement it all. If I can't find anything I like that isn't too gaudy on the usual market, I can possibly look into something like Retro Sound.
                          On another note, it's time to reflect on how far the car has come in just the month and a half since I purchased it. Since purchase I've fixed all four windows, the rear power locks (if you can call spraying a ton of WD-40 on something "fixing" it), changed all the leaking gaskets on the engine and cleaned up the engine bay (still needs more cleaning, though), added the '90 TC fan shroud/overflow bottle and PI air tube, and replaced the missing factory exhaust.
                          The before and after for the engine alone is pretty impressive. There is still some residual oil stuck between the heat shield and catalytic converter burning off, but everything else down there is still dry.
ID:	1281192 Click image for larger version
ID:	1281193 Click image for larger version
ID:	1281194 Click image for larger version
                          I also just happened to figure out my air box mounting problem over the weekend while I was dealing with the oil pan gasket. The '07 CVPI from which I pulled the air box had one of the mounting studs screwed into the front support doubling as a mount for the air box and a hold down for the splash shield. I removed my air box to prep for the gasket change because I was having a tough time removing the overflow bottle tube from the radiator since it was so cold. I noticed an extra hole in the splash shield just behind the one where I had screwed in the stud. I had another large washer nut laying around and used that to attach it to the bottom side. The air box reaches all three studs now.
                          Now that all that's done, I still need/want to do the following:
                          3G alternator swap. I already bought a junkyard alternator which I have yet to get tested.
                          Explorer engine swap. There is a '96 Explorer at one of the local yards that I seem to remember having "bad motor" spray painted on it. I want to grab the non-P heads from that motor and pull the motor/AOD from the Mark VII from which I pulled my power steering pulley. Build this up in the garage and drop it in at a later date along with a MAF conversion.
                          Big brake swap! I want to get this done and install a set of 16" AR Torq Thrust wheels.
                          Disc brake rear end swap. I'll have to do some research into which ones would be best. I decoded my door tag yesterday and, of course, I have the lamest axle of them all (8).
                          Those are the major things. I'm sure there are a million other small things that will pop up along the way. I also want to eventually repaint it along with a color change. I want to paint it a dark blue and replace the vinyl top with a dark grey. I was originally wanting to slick top it, but I think it would just be missing something without it. I was thinking something along the lines of True Blue that Ford used on a lot of its vehicles in the mid-2000s. Here's a great example of a two-tone with the kind of grey I'm looking for on the top.
                          —John
                            Oh, I keep forgetting about the 90+ boxes. So it looks like you won't be able to do the plug & play upgrade. You can still scour yards for the JBL rears and fronts as those will still sound great. The woofer cones on the rears are impregnated with some sort of resin so they're still in the same shape. It's the door & dash speakers that are always sketchy. Like gadget said the ones in the dash are usually fried from sun exposure and the door ones are usually rusty from just being stuck in the door with no added protection.
                            Also, looks like I can't use a '90 TC airbox and such as the box goes right where my air compressor is.
                            And yes, if it didn't work before and now it does I'd say you fixed it.
                              One small thing. The tags arrived today at which time I took the opportunity to install the NOS front license plate bracket I acquired.
                              Pretty sure the J stands for "junk".
ID:	1281209 Click image for larger version
ID:	1281210 Click image for larger version
                              —John
                                At least boxes or anything else with a real bumper upfront doesn't look so hideous with a plate up front.
