Page 3 of 20 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 400
Thread: Buyer's Remorse (AKA "Hideous") - Giraffe's 1990 Grand Marquis LS
  1. #41
    21,412
    ah... that plastic bit. I wouldn't know how to remove that without damaging it or put one on if you managed to get one without damaging it. I would say heat at 150F in a oven (toaster oven) for a couple of hours (inside foil to keep it from out-gassing and contaminating your oven) and then install while hot (gloves might be a good thing), but getting one off a regulator would be the trick.
  2. #42
    38,732
    I've put them back on by using a pair of vise grips. Put it in the track under the glass, put the ball end of the regulator into it, then squeeze it together. Its a pain in the ass, but it can be done. Unfortunately if its out, it might mean the plastic got damaged somehow and it needs replacing. I believe the same parts are used on Mustangs, so there is a fair bet you can get one from LMR.
  3. #43
    GMN Regular Giraffe's Avatar
    Jan 2016
    Cabot, AR
    862
    I can't figure out in my head how it came out in the first place. I couldn't get it back on the arm because the hole was tapered and just would not fit over the stud. The good news is, I called the junkyard in Dallas and they haven't yet crushed the '90 GM. They're going to look into getting me that regulator and shipping it up here.
    On a happier note, I spent the past week piecing together the parts to do the later model intake tube/air box swap. It's not an exact fit, but boy is there much more room on that side of the engine now. I also did a little bit of a spray down of the engine bay with the garden hose. I still plan to power wash it, but I'm waiting on new PCV parts and the intake manifold gasket I ordered to do that. Pictures.
    Clean(er) engine bay.
    Found this written on the passenger side of the header panel support written in pencil. I think this car has a lot more miles on it than I thought. Haha. No matter. Everything that needs to be fixed will be fixed. No matter how long it takes.
    I think the radiator was replaced at some point. The fan shroud was fastened to the radiator with 7/16" bolts and nuts rather than the u-nuts and standard bolts. I grabbed some new bolts and u-nuts online and used several during the install. Looks just like the factory intended.
ID:	46495Click image for larger version.
ID:	46496Click image for larger version.
    All done. The air box didn't fit the available bolt locations. I'll probably look into fabbing some adapter brackets later on. Found a bunch of dead ants under the intake plaque. I really need a shop light.
ID:	46498Click image for larger version.
    I don't get much working time before the sun goes down. Hopefully I can start tackling the passenger side window motors tomorrow.
    óJohn
  4. #44
    Nov 1982
    Wetumpka, AL
    20,428
    I do love progress! Love the new airbox! It helps that you already have the correct inner fender for it
  5. #45
    Jan 2016
    Cabot, AR
    862
    Quote Originally Posted by Grand Marquis GT View Post
    I grabbed the insulated mounting studs from the donor car, but they don't line up exactly. I'll have to fabricate some brackets if I want it to be installed somewhat correctly. I had to force the air tube onto the box and would like to see about getting an improved mounting position which allows me to reduce the stress on the air tube.
    Only thing I have left to do is install the newer washer fluid reservoir. The one I have is out of the same '07 CVPI from which I pulled the air box (same junk yard that has the '90 GM). I grabbed the connector from the car since it's different than my original. I was going to solder it in but ran out of daylight. I'm just going to hold off on that and see if I can find an earlier reservoir that has a motor similar to mine.
    I have so many parts I want to buy, but money is a little tight right now. I now have three cars (and my wife) vying for a slice of the pie!
    Patience...
    óJohn
  6. #46
    Nov 2012
    Shelby Township, MI
    3,027
    Nice! You're not wasting any time on this thing.
    I finally installed my '90 TC air box, fan shroud, and washer bottle recently. I've had the fan shroud laying around for more than year. Still haven't updated my RR thread with pics yet.
    I used a washer bottle from a '92 CV (MIA on all 3 of the '90 TCs I got the fan shrouds and air boxes from) so I still have the low level indicator.
    The '90 TC air box lines up with my '91 inner fender but I think the diameter of the inlet and outlet is probably smaller than the air box setup you have.
    That engine bay looks a lot better with all the dust gone.
    Gone but not forgotten:
  7. #47
    Jan 2016
    Cabot, AR
    862
    Trying not to! It's not in the best of shape, so I'm looking at a lot of maintenance before I can consider it to be 100% reliable. Of course there will be some non-stock mods along the way!
    Thanks for the tip on the washer reservoir. I'm pretty sure there are a few aero cars in the junkyards around here. It would be better if I could just make everything plug and play. Not to mention that the harness for the '07 washer fluid pump has a thicker gauge wire. I don't want to have to worry about pulling too much current on the existing circuit.
    Would you mind measuring the outlet of your air box so I can compare with mine? If it's the same, I'll just get the earlier air box and see if I can make that work.
    General question for everyone: does anyone know if the trunk lock cylinder is interchangeable between GMs and CVs? I found a place that has three complete NOS sets of ignition/door/glovebox/trunk lock cylinders, but it says they're for 1990-1991 CV. I'd really like to get them, but I would hate to not be able to use the trunk cylinder. I like to replace the lock cylinders on my older Fords; nothing beats a nice, tight ignition.
    óJohn
  8. #48
    Nov 2012
    Shelby Township, MI
    3,027
    I should clarify that a bit.
    The '92 washer bottle that I got most likely has the same pump plug as the '07 you got. It's not plug and play, even the low level indicator plug is different. I don't think the newer stuff has the low fluid indicator; that was my main reason for going with the older tank. I also noticed the '92 wiring was slightly fatter gauge, but the wiring was pretty simple since the wire colors were the same between '91 and '92 (BK, BK/W, and PK/Y IIRC, with BK/W shared between pump and sensor, PK/Y to sensor, and BK to pump). Also, I'm not sure if you've done any test fitting, but I only have the rear most bolt hole bolted in on the washer bottle. Considering that the washer has always had issues since I got the car, I'm just excited that the thing works consistently now.
    I should have a chance later to get some measurements, if I can find something to measure with. Things don't seem to stay where I put them...
    Trunk lock cylinder, not sure.
  9. #49
    Jan 2016
    Cabot, AR
    862
    Ah, I see. It would still be nice to have the low-level indicator as you said.
    I've only barely test fit the bottle in the engine compartment. It was difficult to see which bolt hole should be used, so I opted to just finish the air box install and worry about the washer reservoir later. It was already getting dark by this time. Thanks in advance for measuring the air box outlet for me.
    I'm betting the trunk lock will interchange. The only difference is probably whatever cable mechanism is in place to actuate the latch since they're mounted in different locations.
    óJohn
  10. #50
    18,920
    Ive got the same air box set up on my car with a 90/91 inner fender installed and have no issues. Weirdness.
  11. #51
    Nov 2012
    Shelby Township, MI
    3,027
    The narrowest point in the '90 TC air box inlet and outlet is about 1 3/4 inches. I'm pretty sure the later box you have has larger inlet and outlet, it sure looks like it in the picture.
    Pic of the '90 TC stuff:
  12. #52
    Jan 2016
    Cabot, AR
    862
    I wonder if the top of the '07 air box will fit the bottom of the '90 TC air box.
    óJohn
  13. #53
    38,732
    hm, I'm running an early 90s box on an early 90s fender and it fits up OK. Couldn't tell you specifically what it is, but probably 91-92. Much later and the inner fenders got stupid looking to allow better access to the alignment points. Airbox might be 94ish.
  14. #54
    21,412
    Quote Originally Posted by Giraffe View Post
    Nope... the slots changed to the top part instead of the bottom, so that won't work. Thought about that for half a second when I was screwing with such shenanigans on the Mark VI when I had it.
  15. #55
    Jan 2016
    Cabot, AR
    862
    Here's what my air box installation looks like. I have it bolted to the splash shield. The front mount doesn't reach the stud on the header support. Snapped a couple of the engine bay with better light than yesterday.
ID:	46501Click image for larger version.
ID:	46502Click image for larger version.
ID:	46503Click image for larger version.
    Regarding the aforementioned battery hold down bracket, I figured out from another thread on this forum that I probably needed the other bracket. Found one on nospartsltd. The hold down bolt is a little too long, though. I'll look into getting a shorter one next week.
ID:	46505Click image for larger version.
    óJohn
  16. #56
    Apr 2015
    Southern Commiefornia
    2,345
    Weird, I had an '04 p71 airbox in my other '90 and I think it was the same size. Now i'll have to look. In my case though, I cut off the part of the airbox outlet where the slot for the Maf was to shorten it and accommodate my C&L MAF. Worked out perfectly although I had to trim the mustang zip tube a bit. Once I get it all back on the new car i'll take some pics.
  17. #57
    Jan 2016
    Cabot, AR
    862
    I actually do have an intake tube and air box I snagged off of a Mark VII. Same as goes on the Mustang. I should try that and see how it fits. Not sure if the air box side of the tube would be too small for the PI air box.
    I also found a Ford replacement part for the window regulator roller/slider that's missing/broken on my driver's door (these). Some sites say it fits our cars, others don't. I purchased some; it's worth a shot!
    óJohn
  18. #58
    Jan 2016
    Cabot, AR
    862
    A little more progress today. The roller service parts came in; the driver's window/regulator is put back together. It still doesn't work; I'm thinking the motor may be shot. All you get is a *thunk* and a fraction of movement with the switch. Pictures.
    Drilled out the old stud: Click image for larger version.
ID:	46528 All put together: Click image for larger version.
    The Motorcraft solenoid I ordered on 22 November finally arrived today. It cranks with the key now.
    No more red wire!
ID:	46530Click image for larger version.
    I ordered an intake manifold gasket set and a new PCV grommet/connector/valve which all arrived this week. I'd like to replace the gaskets/PCV tomorrow, but I still need to go buy some thread sealer and a few odds and ends before I want to dig into it. She's coming along.
    óJohn
  19. #59
    Dec 2011
    Yonkers NY
    4,045
    Did you get the PCV filter?
  20. #60
    Jan 2016
    Cabot, AR
    862
    Yes. Forgot to mention that.
    óJohn
