300-350 at the wheels? Gonna need a ZF for that, not an M5. The small-block version of the ZF is wide-ratio with 5.72 first gear, that will shit slower than any T5. The close-ratio diesel gears may swap, but you'll need to do that reusing the small-block shafts, for which you'll need to completely tear down the transmission internals - the cheater way of swapping gears and shafts together as a full matched set only works with big-block transmissions as they have the same input shaft as the diesel ones.
Don't take me wrong, you can certainly try a M5, as they are cheap and plentiful enough. But people have been killing them with 200hp engines ever since they came out, true that's mostly cause they overload the truck and then beat on it, but you'll be replacing the payload with engine power, as far as the driveline is concerned the two have similar effects on it.
