Page 20 of 21 FirstFirst ... 1018192021 LastLast
Results 381 to 400 of 412
Thread: The 97 CV "Tank of Justice III" (TOJ3)
  1. #381
    38,775
    so when are you going to Windsor swap that thing so it runs for more than 6 months between engine failures?
  2. #382
    Vinyl Cheese, Meat Pasty SVT98t's Avatar
    Nov 2005
    Upstate, NY
    5,158
    Probably after I do this 2 more times.
    08 Lincoln Navigator L - 183k
    03 Mercury Marauder- 61k
    97 Ford Crown Victoria HPP "Tank of Justice III" (TOJ3) - 193k -->578.9 miles on ONE tank of gas<--
    Quote Originally Posted by pantera77 View Post
  3. #383
    I post a lot...
    Dec 2011
    Yonkers NY
    4,056
    Snort
  4. #384
    Nov 2005
    Upstate, NY
    5,158
    Got it all kinda in. Forgot small things, like:
    I kept the 03 timing chain cover. I failed to realize that it does not have the provisions for coil packs on the front, and it takes a different belt then what I have on hand. I'm gonna convert it to COPs, and make the harness for it, since I have that stuff on hand.
    Also, the 03 intake manifold has one coolant sensor, whereas the 97 has 2. one for the gauge, and one for the fan, I presume.
    I have to install the RAS pump too. I have it. Just gotta put it in.
    Progress.
  5. #385
    Jan 2007
    Westmont, New Jersey
    10,349
    Quote Originally Posted by SVT98t View Post
    I hope you're swapping the computer as well. Because you can't wire up the COP coils like a waste spark. They just don't work for some reason. Thain went through all that crap with Jason's 93 when we swapped the PI engine in it.
  6. #386
    38,775
    I actually followed a guide from someone who had done it. Apparently it can work, it just didn't work for me. The modular and I are not fast friends.
  7. #387
    Nov 2005
    Upstate, NY
    5,158
    Well, I'll let you guys know if it works for me.
    It's either going to work, or it isn't. BOOM.
    I'm making the harness tonight; Inside, next to the fireplace. I already brought a folding table in to work on, lol.
    So, tomorrow night might be go time. Or Friday. I'm hoping to at least attempt to drive it this weekend.
  8. #388
    Member Pvt.Hudson's Avatar
    Aug 2005
    Assachusetts
    68
    With the 2 temp sensors, one goes to the cluster other goes to the PCM.
    1997 Grand Marquis LS HPP
    - Richard
  9. #389
    Jan 2007
    10,349
    Maybe the PCM driven EDIS is able to operate both coils? I honestly couldn't tell you why it didn't work.
  10. #390
    Mar 2010
    Lewisville, TX
    21,432
    Theoretically, it should have worked. I have my theories as to why it didn't, but without the original PCM and wire harness to test, I couldn't tell ya.
  11. #391
    Nov 2005
    Upstate, NY
    5,158
    Harness is just about together. I just have to solder a connector on the LH side. I did the right side last night, just got tired.
    I'm hoping to have it installed tonight, throw the starter in, and see if it works, doesn't work, or starts on fire.
    Those are pretty much the only outcomes that are possible right now.
    Maybe drive it tomorrow? Yikes!
  12. #392
    Nov 2005
    Upstate, NY
    5,158
    Harness is installed in the car.
    Need to install the connectors in the car and the starter and see what happens.
    Someday....
  13. #393
    Nov 2005
    Upstate, NY
    5,158
    It runs and runs well.
    I kinda forgot one thing though. The 97 has 2 coolant temp sensors. The 03 has one. I never swapped over the intake manifolds, nor did I even bother to look at them. So now I either rip the manifold out and swap the crossovers, or tap in a new sensor.
    Yuck.
  14. #394
    Mar 2010
    Lewisville, TX
    21,432
    tappy tap tap.
  15. #395
    I post a lot... pantera77's Avatar
    Oct 2008
    Buffalo, NY
    4,980
    That was a very nice low mileage engine, out of one of the more popular cars on CVN lol.
  16. #396
    38,775
    drill and tap is your friend.
  17. #397
    No mean-spiritedness here. IPreferDIY's Avatar
    Jul 2014
    Canada
    1,926
    I don't think drilling and tapping that would be nearly as bad as dealing with a spark plug hole. With the coolant drained low enough, I would think you could use WD-40 as a cutting fluid (whether you are using a cheap drill and tap or not, since you're going into aluminum) without too much concern that a vacuum cleaner won't pick up all the chips (with at least one coolant hose disconnected). I suppose you could even use a flashlight and cotton swab (possibly with a magnifier) to get any chips that are stubbornly stuck to the inside of the crossover.
    mods: air filter box "tuba" (in place of the "trumpet"), headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, NKL4 PCM (from a 2000 CVPI, nothing great there apart from highway cruising), KYB Gas-A-Just shocks (after >202,000 km on originals)
  18. #398
    38,775
    all you need is an aluminum magnet. It'll pick the chips up no problem.
  19. #399
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,327
    AL magnets are awfully expensive, maybe you can rent one...
    10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
  20. #400
    Sep 2008
    Whitestone, NY
    18,948
    Our fabrication shop primarily works with aluminum. I bring that point up all the time. Nobody listens to me.
