Page 12 of 12 FirstFirst ... 2101112
Results 221 to 240 of 240
Thread: The 97 CV "Tank of Justice III" (TOJ3)
  1. #221
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,458
    Does the a/c work?
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    Always good to have spare parts!
  2. #222
    Vinyl Cheese, Meat Pasty SVT98t's Avatar
    Nov 2005
    Upstate, NY
    5,017
    Yes it does.
    Sent from my SM-J727P using Tapatalk
    08 Lincoln Navigator L - 161k
    03 Mercury Marauder- 58,171 miles
    97 Ford Crown Victoria HPP "Tank of Justice III" (TOJ3) - 176k -->578.9 miles on ONE tank of gas<--
    Quote Originally Posted by pantera77 View Post
  3. #223
    Nov 2005
    Upstate, NY
    5,017
    Tank is still doing Tank things.
    Dropped a right front tire in mid-August.
    Everything is still working well. Knocking out between 23-25mpg average per tank now. It should only go up now that school has started; longer distnace but ALL highway = better mpg.
    Yup.
  4. #224
    Nov 2005
    Upstate, NY
    5,017
    Air ride decided to take a shit.
    I put new bags in it last year and it was good.
    Compressor kicks on, but the back isn't going up. I'm thinking there's a leak in the lines somewhere.
    Any input?
  5. #225
    No mean-spiritedness here. IPreferDIY's Avatar
    Jul 2014
    Canada
    1,527
    Not sure if it's the kind of input you're contemplating, but what came to my mind was spraying soapy water at the hose connections.
    mods: air filter box "tuba" (in place of the "trumpet"), headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, NKL4 PCM (from a 2000 CVPI, nothing great there apart from highway cruising)
  6. #226
    I post a lot...
    Dec 2011
    Yonkers NY
    3,576
    probably an air leak but after you see if the O-Ring blew you can check for hot and ground at the connectors that power the spring solenoids. Black is ground the other wire is hot. (at least in 03)
  7. #227
    36,265
    yeah, soapy water is the answer. Possible the vent solenoid jammed open. If that happens, nothing will actually leak but all the air will dump out when it tries to fill. The vent solenoid outputs to a nipple on the side of the compressor. I think it should have a hose on there to a muffler that lives somewhere up on the header panel, kind of near the air filter. The lines rarely are a problem unless they got damaged, but the O-rings can fail if not installed right. Air lines can also come out if the ends are a bit too buggered to stay in the fitting. If thats what happened, just lop the last inch off with a razor blade, sand the sharp edge off and plug it back together.
  8. #228
    Nov 2005
    Upstate, NY
    5,017
    Thanks for the responses.
    I'm going to check through everything tonight.
    I may order a pair of solenoids for the bags, depending on what I find.
  9. #229
    36,265
    Those rarely fail honestly, the O-rings are more problematic. If you change them, make sure you lube them first. Jamming it in dry will result in an unfavorable outcome.
  10. #230
    Nov 2005
    Upstate, NY
    5,017
    Well, I ordered the solenoids anyways. They come with new O-rings.
    It did work yesterday on the way to lunch, but failed on the way home. That was the first time it worked in a week. That's what led me to believe a solenoid was bad. Intermittent function. If it was a leak, it would be broken all the time.
  11. #231
    Jul 2014
    Canada
    1,527
    You might want to consider replacing the dryer on the compressor, or 'renewing' the dessicant in it by baking it dry. If there's a problem with the solenoids, maybe it developed from moisture in the system.
  12. #232
    36,265
    Check the wiring to the solenoids while you're in there. I had one break right at the plug, causing one spring to not inflate.
    agreed on the moisture problems too. If the solenoids are soaking wet when you pull them, pull the drier off, open it, and cook the desiccant. Low temp in the oven for a while will do it, or short bursts in the microwave. Don't want to overheat them or the beads will crack. If you dial the power down on the microwave that might also work. They will go from tan to a blue-white color when dry.
  13. #233
    Nov 2005
    Upstate, NY
    5,017
    Will do.
    Air ride failed all day except it worked on the ride home from piano lessons.
    I'll probably get into this Friday night.
  14. #234
    Nov 2005
    Upstate, NY
    5,017
    Air ride worked on the way into work today.
    Hmmm.
    It started working only because I ordered parts for it.
  15. #235
    Member BigMerc96's Avatar
    Jun 2011
    I can see Detroit from here
    348
    IDK if it has been said yet or not, but if the car is at ride-height, turn off the RAS system via the trunk switch. That will rule out an electrical issue because the system will not be doing anything electrically, so it theorhectically should maintain height for a week or more (My Town Car has gone as long as a month before I noticed I forgot to turn it back on because the warning light is disconnected from when it had coils). If it holds height with the system off then you surely have an issue with one of the solenoids sticking, vent solenoid on the compressor is not unlikely because if it sticks open the system will deflate any time the spring solenoids are commanded open even if its supposed to be filling the bags. You'll actually see the car dropping while the compressor is running if/when that happens. Same for if there is a hole in one of the lines.
    The lines are not under any pressure unless the system is actively venting or filling. You can have a small leak in the lines and the system should still operate so long as the air leaking out is less than the amount of air the compressor can pump in, it will just take longer to fill the springs and may reach the time-out and shut down the compressor. The system does have a time-out for filling operations, if its seeing that the compressor is running and the car isn't raising it will shut down to prevent the compressor from overheating, I believe there is also a hard thermal shut off built into the compressor too.
    If the car still sinks with the RAS turned off then you have a leak at one of the springs. That will either be the springs, the solenoids, or the o-rings that connect the 2.
    I'm using lines, bags, and solenoids from a '94 in my '97 and they all still hold, but I did lube the o-rings when I put them together to avoid pinching them. I fully expected to have to replace some of that stuff and was just using the junkyard parts to see if the system was salvageable since I bought the car with coils installed and had no idea if the compressor or anything else was still good. But that was 5 years and 50k miles ago and its still working.
    -Steve
    1998 Mercury Grand Marquis LS HPP ~95k miles, slowly acquiring modifications.
    1997 Lincoln Town Car Cartier ~145k miles, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust, Cats ran away, KYB Gas-A-Justs, P71 front sway bar, air ride reinstalled, Blinker Mod, Projector headlight retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, all natural weight reduction as the parts fall off..
  16. #236
    36,265
    if you have a bum compressor relay it will do this too. THe solenoids open, the system thinks the pump is going, but in reality it just vents out. It would be very unusual for both solenoids or springs to fail at the same time.
  17. #237
    Nov 2005
    Upstate, NY
    5,017
    My biggest issue is that it's intermittent. Sometimes it won't fill up for days, then it'll work for a trip into town, then fail on the way home.
    Anyways, it did inflate on the way to pick up pizza last night. So I turned off the RAS while it was up. It hasn't deflated yet, so that's nice.
    I'll take another look at the compressor vent line today, but I honestly feel it's one of the solenoids. (I bought two anyways to replace).
    I'll be digging into it tonight.
    Thanks for all the help mangs.
    For having three vehicles with RAS, I certainly don't know too much about it, lol.
  18. #238
    Sep 2014
    Warren, MI
    4,871
    Mmm pizza.
    Yes, that's all I got out of all that.
  19. #239
    36,265
    I've got two with four wheel air. Its not that complicated, usually you figure out how it works when it fucks up.
  20. #240
    Nov 2012
    Shelby Township, MI
    2,465
    Hmm... Wrong thread. This is not the what you're working on thread.
    Sly Edit: Fixed. Moved the post to the correct thread.
    ~ 1997 GMC Yukon - wannabe winter DD - I'll fix it eventually
    Gone but not forgotten:
