GMN Chat Room | GMN's STORE!! | GMN's Gallery | Please!! |
One thing nice about owning a Lincoln is that you can easily justify adding weight on the basis that its supposed to be a luxury car anyway.
Getting shit done.
It came equipped with a mechanical and an electric fan. Well, it doesn't need the mechanical fan anymore. It has been removed. Plus, I can install my sweet Mark8 electric fan. This brings the total weight removed to 18 lbs, which, brings the weight down to 3599 lbs. Lol.
Maybe more work tonight. I'm out of propane, so we'll see.
08 Lincoln Navigator L - 193k
03 Mercury Marauder- 62k
97 Ford Crown Victoria HPP "Tank of Justice III" (TOJ3) - 193k -->578.9 miles on ONE tank of gas<--
Isn't the trans fluid flammable?
Nice!
George Burns
Whys the ass squatting so hard?
Need to paint your engine hoist green so it matches everything else. ;-p
I won't paint everything green. I like being able to distinguish between what's supposed to go in the car, and what I use to fix the car, lol.
Shit. Ive been using a jack wrong all these years.
I had to use a screw jack to help beat something off today. Seems Ryan and I go about things in the same manner.
Do you even lift bro...
Originally Posted by gadget73
Originally Posted by dmccaig
Ok, heading back in to the garage after the Christmas weekend.
All the rustproofing will be done in the engine bay, and the new trans will be cleaned up and painted appropriately. Then installation of the J-Mod, pan, and larger output shaft housing.
I still have to put the old engine on a stand and pull off the old exhaust manifolds and swap them over to the aluminum motor.
The combo might be going in next week. We'll see.
End of the year update:
I never planned on buying this car.
Mileage hasn't changed. It's still at 165,970. Still have to install the drivetrain. Not sure if I'll get to that soon.
But plans are to get it up and running as soon as possible!!
Sent from my iPad using Tapatalk
Got a little work done tonight. Mostly organizing the garage and getting ready to get down to business.
I removed the exhaust manifolds, motor mounts, and A/C compressor idler bracket.
Gotta swap that stuff over from the old motor (minus the bracket, since it actually has A/C).
More progress tomorrow.
Transmission is done. Jmod C/W. New pan installed. Trans is now resting on a tire awaiting install.
Put the spent TOJ3 motor on an engine stand.
Took the old exhaust manifolds, and motor mounts off it. I need to clean up the mating surfaces before I install them on the aluminum motor.
I still need to clean up the engine bay and put rust inhibitor/encapsulator/destroyer on everything. I might get to that on Wednesday.
Making progress!!
Ok, after a crazy week or two, time to get back to business this evening.
