Page 21 of 21 FirstFirst ... 11192021
Results 401 to 412 of 412
Thread: The 97 CV "Tank of Justice III" (TOJ3)
  1. #401
    Vinyl Cheese, Meat Pasty SVT98t's Avatar
    Nov 2005
    Upstate, NY
    5,158
    You can fit a rag in underneath the spot in the crossover. It hasn't been topped off with coolant yet, so there a win.
    Picked up a cheap tap set today. I NEEEEEED to finish this paper by Monday though, so it's got most of my attention now. I really shouldn't have been working on the car. I just wanted to know if it would run well or not. Now I have my answer.
    08 Lincoln Navigator L - 183k
    03 Mercury Marauder- 61k
    97 Ford Crown Victoria HPP "Tank of Justice III" (TOJ3) - 193k -->578.9 miles on ONE tank of gas<--
    Quote Originally Posted by pantera77 View Post
  2. #402
    38,773
    Cheap taps are really f'n expensive when they break. Pipe taps are tapered, not somewhere you want to have one bust. On the bright side its a fairly large tap, so less likely to be a problem. Never buy a cheap #6-32. Its the most miserable tap in the world anyway, and shitty ones will ruin your day.
  3. #403
    Gonna buy me a Mercury BoulevardRide's Avatar
    Jan 2018
    ne
    159
    When i worked at a bike shop we'd put grease on the tap to keep shreds out of the engine.
    Never heard of an aluminum magnet, will have to look that up. always learning something here
    96 MGM
    Cruisin up and down the road...
  4. #404
    Nov 2005
    Upstate, NY
    5,158
    Oh, it's a pipe tap. 3/8 -18 NPT. My rag fits amazingly well in the crossover. I've been vacuuming after every drill bit I use. I started at 5/16, and worked up to 3/8, however, i need a 9/16 for the tap. and I ain't got one. Yet.
    It can wait.
  5. #405
    38,773
    Harbor Freight has a Silver and Deming drill bit set that gets you from 9/16 to 1" by 1/16". They're not amazing but they do work. Might have to re-sharpen them, my 3/4 bit was ground shitty from the factory and would not cut. 30 seconds on the bench grinder and its fine. S&D bits all have a 1/2" shank so human size drills can spin them. I know I got mine for a lot less than the 40 bcks they list for now. prob can catch it on sale at some point. Its not a tool I use often but once in a while you need a big drill bit.
  6. #406
    Nov 2005
    Upstate, NY
    5,158
    Got the wiper cowl installed. Forgot to plug in the wiper motor. Removed the wiper cowl to plug in the wiper motor. Forgot to route the wiper juice hoses. Removed the wiper cowl. Ran the pisser hoses. Reinstalled wiper cowl finally. Installed the valance, wipers, and seal.
    Managed to get the bumper cover on, but not bolted on because my boys were being hooligans and we had to go inside.
    I tried to test the wipers, but the battery was about dead and couldn't check anything.
    Waiting until I have to leave the house to make the run for the drill bit. It's not a big priority. It can wait.
  7. #407
    Nov 2005
    Upstate, NY
    5,158
    Tap worked great. Had to go buy a drill with a 1/2" chuck on it since I didn't have one. No leaks from either sensor. The temp gauge works now. Oil pressure gauge still doesn't work. That's probably because the one from the new motor got smoked. And the one from my motor got smoked as well, lol.
    Speaking of smoked, my hood latch got bent to FUCK. I inadvertently hit it with the engine/trans combo on either removal or installation. I have to take the latch out of the car, disassemble the latch, and put the latch armature in the vise and try and straighten it , without breaking it.
    Test drive went well. Needs a bit more trans fluid, but it does pull quite well.
    A few more things to button up, and then maybe finish installing the window regulator on the right rear; that I started in August?? F, lol.
    It needs tires too. But I'm not really driving anywhere right now. So it's all good.
  8. #408
    38,773
    'bout time it goes under it's own power again
  9. #409
    I post a lot...
    Dec 2011
    Yonkers NY
    4,055
    Good news.
  10. #410
    Sep 2008
    Whitestone, NY
    18,945
    Yay.
  11. #411
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,326
    Cool!
    10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
  12. #412
    Mar 2010
    Lewisville, TX
    21,432
