The dash speakers are 5 inch (5.25" speakers do NOT fit). You can get 4 inch speakers and adapter plates (I got the adapters from Crutchfield) to fit the mounts.
Audio upgrade without touching the factory head and wiring.
part number for the dash speakers adapter: Metra 82-5500 (Crutchfield no longer carries them... jerks)
http://www.installer.com/item/displa...php?it=82-5500
I'm using 3/12 or 4" speakers with those adapters. Can't remember which without looking, but probably 4" if thats what the adapters fit.86 Lincoln Town Car (Galactica).
Originally posted by pantera77 View PostFactory JBL stuff (when actually working and with speakers that haven't disintegrated) actually sounds pretty damn decent for 30 year old car audio. Beats the hell out of an ugly aftermarket headunit any day.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostThis. Didn't read the rest of post but provided you can find JBL dash speakers that aren't roached and a JBL amp which hasn't pooped it's pants, you're all set.
Sent from my iPhone using Tapatalksigpic
I had the factory deck + JBL stuff for a minute. I thought it sounded good until I dropped my Sony deck in, blew factory stuff away. I like the factory look myself but Sony was a decent compromise as at least it wasn't gawdy and I could change the color so that it lights up green when the lights are on and white when they're not. Tucks in nicely where the old radio was. Only thing I hate is the volume knob as it has ugly illuminated ring. But that aside it plays my ipod, does Bluetooth, 5V preouts and has HD radio. Was only 180 bucks or so too. Was not that loud when using preouts from deck to JBL amp, actually it was milder than the factory stereo was with the JBL amp. Caused me to just replace the entire factory JBL amp with an aftermarket JBL amp so now I've got a sub & junk. Freakin' awesome. Anyway, if you just used an aftermarket deck & sent line level inputs to the JBL amp it will work just fine. If you over drive the amp you'll know as it will either cut out or blow the fuse. Tis ok, Ashley has been rockin' her TC's radio that way for nearly 3 years.1985 LTD Crown Victoria - SOLD
If you have one of the factory tape deck head units that could pair with the CD changer, you can fit a line-in fairly easily. It needs a small amount of wiring magic and a stereo phono jack that will close the circuit when you unplug the cord from it but thats no big deal.
My Mark VII has an aftermarket stereo with the RCA to JBL connector in there. Fairly poorly made, but once you finally get the damn thing to plug together it works fine. Unfortunately the factory CD player died too many times to be fixed anymore. The Sony in there is an ugly POS, but it was free and i was able to make it work with a line in for under $20. I have a 90s era factory tape deck to eventually go in there, but it seems to need a little bit of adaptation to make it go. Not sure why, but I think it has something to do with the remote amp power wire not being the right voltage, or perhaps its on the wrong pin. The radio works, the amp works, the radio just won't turn the amp on. Haven't investigated further.86 Lincoln Town Car (Galactica).
Put some tweeters in the dash and run them off a seperate amp. Helps bring the sound up off the floor some. I mounted tweeters on the A-pillars of my '90 in 2008. Love them.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
You can find door panels that have the grilles, might not even need to run the speaker wire for them.
Gadget, I think all of the Lincoln tape decks 88+ are compatible with the standalone CD player. When I pulled mine out (it wasn't a factory JBL car) it had the plug going in for the speaker outputs and then an empty slot where the CD player would plug into. I didn't know that was where the CD player went until I tore into a Town Car that had the CD player, as it was using that slot.1985 LTD Crown Victoria - SOLD
My 88 required me to run the wires for the door speakers.
Originally posted by DerekTheGreat View PostGadget, I think all of the Lincoln tape decks 88+ are compatible with the standalone CD player. When I pulled mine out (it wasn't a factory JBL car) it had the plug going in for the speaker outputs and then an empty slot where the CD player would plug into. I didn't know that was where the CD player went until I tore into a Town Car that had the CD player, as it was using that slot.86 Lincoln Town Car (Galactica).
If you have one, I wouldn't throw it in the bin. I could probably fix this one with some superglue or something, but its so far down on my list of priorities its not even funny. I haven't driven the car it goes in going on 2 years now, making the radio work is not exactly crucial at this point.86 Lincoln Town Car (Galactica).
Which car would it be for and would it be a tape deck or CD player?? I can't remember which radio we were talking about. I did score more pre '88 JBL stuff from an '86 TC, Amp was one of those weird deals I posted before and I didn't take it since it was rusty. I can't remember, are the air suspension parts the same 86+? The compressor was in the trunk and looked a bit different but the level sensor seemed to be the same so I took that as I'm trying to figure out why Ashley's doesn't work. Compressor works if you give it juice...1985 LTD Crown Victoria - SOLD
