Page 27 of 28 FirstFirst ... 1725262728 LastLast
Results 521 to 540 of 554
Thread: My 1987 Mercury Colony Park
  1. #521
    Sep 2008
    Whitestone, NY
    18,774
    86+ is roller for the Box 302.
    Regarding the cam, I was able to find a stock HO grind on corral.net for $40 shipped couple years back. Supposedly has 42k on it. Then again, stock Fox parts are exploding in value. Saw a stock catted H-pipe for $1350. It was NOS but still...
    I seen that as well. The price has dropped significantly but it is still UP there. Funny I put a NOS catted H pipe on my pile a few years back. Who knew I should have saved it for stupid money.
    Zack.....how much of a rush are you in. I have an HO stick that came in the rebuilt block I purchased for my car back in 2014/15. I pulled it and stored it. I may have a gig coming up in Atlanta (mid august) and am not opposed to just dropping it off. You let me know.
  2. #522
    38,247
    I doubt 1.7's are a problem. The only time you really risk valves meeting the piston is with long duration cams, and the rockers don't add any real amount of duration. I also don't know that they add enough extra lift to justify their installation really. Use them if you have them but I wouldn't spend a lot of money on them. Put that money into a better intake instead.
  3. #523
    Default My 1987 Mercury Colony Park
    Hmm thats news to me. So we have roller cams?
  4. #524
    Nov 2014
    Evans, GA
    1,495
    Quote Originally Posted by 87GrandMarq View Post
    Yup. Pickup 302s are the weird ones that kept flat tappets up until 1993, finally switching to roller in 1994.
    Just slowly gathering parts and having them ready, so I'm not rushing to acquire everything.
    If you're down this way, I'd certainly be more than happy to buy that HO stick off you.
  5. #525
    Ok Ive always known for them to be flat tappet, you learn something new every day
  6. #526
    Sep 2008
    Whitestone, NY
    18,774
    Quote Originally Posted by Kodachrome Wolf View Post
    Nah. Don’t worry about that. You went out of your way and helped me out before. Plus it is just sitting around. I have no problems just gifting it to you.
    I will keep you up to date on if and when this would be.
  7. #527
    38,247
    86+ is roller, sometime in 85 the roller compatible blocks came out. Some 85s have them, some don't. Converting needs the holes drilled and tapped in the lifter galley, but thats not all that difficult. The distributor gear is different too, steel for roller cam, iron for flat cam. The iron gives to the steel, so if you're going to have a mismatch you want it to be the distributor. Still not good since all the metal goes into the engine but if you eat the cam gear off the only fix is a new cam. At least the distributor you can just replace or re-gear.
  8. #528
    I knew about the late 85+ blocks being roller but is the stock cam roller? I always thought it was a flat tappet cam.
  9. #529
    Nov 2014
    Evans, GA
    1,495
    Stock camshaft from late '85 and onwards was roller for car engines. Flat tappet cams are in the '79-'85 cars.
  10. #530
    Good to know thanks
  11. #531
    Nov 2014
    Evans, GA
    1,495
    Got a Class III/IV receiver installed today. Got this Putnam unit free from TecNickal, and reportedly came used from like a '92 Crown Victoria.
    Unlike most I see for Panther applications, this one did not have the angled rear mount, but was instead totally flat. Compared to the installation on the '97, I had to drill the rear holes (towards the gas tank) vs drilling front holes (towards the bumper). I also had to level it a bit towards the front since it was going to unevenly contact where the bumper mount is attached to the frame.
    I did notice what while the unit was generally level with the frame, the receiver opening is angled down a touch. I am well aware it has been dragged on the ground having worn down the tube at the bottom. I'm wondering if it was overloaded or was rear ended at some point and warped the tube a bit. That amount of wear isn't from hitting a driveway once in a blue moon.
    As long as it works, its fine. If I have issues, I'll just get a comparable replacement.
  12. #532
    Mar 2006
    Bedford, VA
    5,295
    Maybe dragged in the salvage yard? They can tear up some stuff getting the cars set for picking.
    1988 Crown Vic Wagon - daily
  13. #533
    Sep 2008
    Whitestone, NY
    18,774
    I pulled a trailer hitch from a wagon before and it used wedge shaped shims to set it straight in the frame rails. Don’t remember if it was front or back but it was not all four corners. Was not needed when installing it into my crown Vic.
    Interesting bolt together type. That does look like it was dragging ass for a long time. Must have been a good spark show.
  14. #534
    Member BigMerc96's Avatar
    Jun 2011
    I can see Detroit from here
    517
    Yep. There are indeed wedge shims on a Wagon. Frame rails must be straighter on them behind the wheels or something. My buddy's '91 wagon had the factory installed hitch being a tow package car and all. We compared it to the Curt hitch he put on his '03 CVLX, they were damn near identical aside from the wagon having shims, IIRC they were at the front side closer to the axle. I want to say the Curt came with said shims, but I could be totally wrong and just thinking of it being mentioned in the paperwork. All I know is that the factory hitch on the wagon was still very solid and we used it more than a few times to haul stuff, like his '90 Gutlass Ciera on a tow dolly. Interesting side note, that 1990 Gutlass was actually a month newer than the 1991 Grand Marquis wagon, Ford started building '91s hella early, iirc that thing was a 4/90 build.
    -Steve
  15. #535
    Nov 2012
    Shelby Township, MI
    2,950
    Usually damage done at the JY is fresh and obvious. I'm convinced that I'll never find a driveshaft in the yards here that hasn't at least been dinged by loader forks. It looks like the lower lip of the receiver opening has been ground off, that would have been a ton of dragging at the yard to accomplish that.
    +1, '91s were built pretty early. The Scab also has a 4/90 build date. The Ice Car is within normal model year range at 11/90.
    ~ 1997 GMC Yukon - wannabe winter DD - returning summer 2020, I finally have an engine
    Gone but not forgotten:
  16. #536
    Mar 2010
    Lewisville, TX
    21,260
    If the original owner of that hitch had a steep driveway or workplace with a steep entry and scraped every day... it would eventually look like that as well. I know I've ground some off the bottom of the hitches that have been on my 93. Not that much mind you, but still.
  17. #537
    38,247
    I've bottomed my Towncar out a few times in that spot. 4 people and a really steep driveway does it. Of course I was running one of those double ball things, so it had one ball sticking down for even more inclination to grind. Just typing that sounds painful.
  18. #538
    As somebody who has towed with his wagon for over 3k miles, let me tell you that receiver drags and drags hard. Any kind of ramp for a gas station, a speed bump, a slightly steep driveway it would drag real good. Mine is a Curt one and it had the shims to make it mate it properly to the straight frame of the wagon.
    I even had new shocks, new wagon specific rear springs, all that good jazz.
    To be fair the trailer was pretty loaded up. Had 2 toolboxes full of tools, 2 giant bins of old pig iron Ford parts, a TV, 2 computers, video game consoles, and everything else in my life I could fit in a 8x6 trailer.
  19. #539
    Mar 2010
    Lewisville, TX
    21,260
    This is why I have the Airlift 1000 load helpers on mine. It'll level out.
  20. #540
    Nov 2014
    Evans, GA
    1,495
    HO project is slowly creeping towards the actual work aspect. Got the last major component, the fuel injectors, a la a '96 Marquis.
    Got a kit to replace the pintle caps, filter baskets, o-rings, and little plastic spacer thing-a-majig. I figured refurb'd flow match injectors would be nice, but I doubt on a generally stock engine it'll make a noticeable difference.
    So at this point, I've the following awaiting install:
    -Stock HO Camshaft (A big thanks again to David!)
    -19 LBS fuel injectors
    -'87 Mark VII LSC PCM
    -1.7 Roller Rockers
    However, I plan on helping Nick finish his Explorer swap first, then we can tackle this job. Then we get to figure out which wagon does better: An '89 with an Explorer 302 and 3.08s vs an '87 with a HO swapped LoPo and 3.27s.
    A good question though: Is there any special procedures I need to follow as far as breaking in a roller camshaft goes?
    I also did get one of these:
    It's a Ford OE aftermarket option for those wanting DRLs. It's suppose to tap into the low beam lamp circuit, however I think there's an option between half power on the circuit and full power. Since I'm running a relay harness, I'd need it to be on the full power output since I doubt the relay would agree having less than 12v going across it.
    The next future project that lays after all of that is a '92 LTC underhood fusebox to replace the rats nest of fusible links. I'll also integrate the headlight relays/fuses and cooling fan relay/fuse combos into it as well. I've just got to do a little research and reading threads here to determine the closest fuse options to replacing the links. Photobucket has effectively ruined one of the threads and the pictures are just blurs.
Tags for this Thread
