Page 33 of 33 FirstFirst ... 23313233
Results 641 to 652 of 652
Thread: My 1987 Mercury Colony Park
  1. #641
    Jan 2008
    New Jersey
    3,070
    Quote Originally Posted by Kodachrome Wolf View Post
    Which stall rating did you go with? We’re you preferable to the 2500 RPM stall, or something else?
    Wiring is very much the same, just a different connector, and one less wire. Essentially the plug just has the yellow sense wire and green/red lamp wire. Given the install is very similar to the 3G, it wouldn’t be a hard thing to do if someone opted for it. I figure the only folks that would be out of luck are large case folks that had an externally regulated unit, since I don’t think Ford made a 6G that would fit a bracket like that.
    Yeah I got one that’s rated at 2400-2600
    That’s good to know! I just ordered a large case 3g
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
  2. #642
    Nov 2014
    Evans, GA
    1,727
    Got started on that underhood fuse box job. I've already partially vented my frustrations regarding some of the brilliance to the design of the fuse links in the "What Are You Doing?" thread, simply because it's so strange that so many wires are all sharing the same darn color, but all power their own respective circuits. I get maybe from the standpoint it's to indicate, "Hey, this is constant hot 12v power!", but it's not indicative to what it's powering.
    Anyway, I've been using 87gtVIC's photos to get the most mileage out of this since the original thread had the photos nuked out of it.
    I had to get creative to rule out some circuits that I couldn't prove out under the hood:
    I managed to get lucky a few times on the massive bundle of yellow cables. Had to determine who went to the trailer tow, defroster, and air suspension relay circuit. Similar to 87gtVIC, I had a random wire not labeled anywhere, but mine was a thinner gauge yellow cable.
    I've also probably made a mistake in fuse box selection. I wound up with an early Aero Town Car box, which is fairly chonky. I have already configured it to my specifications. I just need to re-label the inner lid. I've got all my circuits written down in the back of my EVTM.
    I'm doing the smart thing and moving the horn relay over into the box, and I'm also putting my headlight and e-fan relays in there too.
    About 75% filled in.
    I've got the other relays and the red base already fitted. I've just got to get more 30 amp fuses. I've already added extensions to most of the wires to get them to clear the bottom of the box, however I need to get some heavier gauge wires for four remaining circuits. Also need more wire loom.
    Fitment in the car is gonna be the next fun part. There's an area I can land it where it'll be right up on the brace bar, but clear of the battery hold down and the hood. Definitely will have to remove that bar to open the lid since this one is hinged. I've also got to make a bracket to hold it level on the fender liner. The only thing I already know I don't like about where it needs to sit gets it all up on the A/C lines. As long as I've got some abrasion protection over there, it shouldn't really be an issue though.
    I'll be much happier once everything is wired in, it works, and I never try this job again.
    -1964 Comet 202 (116K Miles) - Awaiting Resurrection
    -1997 Grand Marquis LS (222K Miles) - The Daily Workhorse & March 2015 + January 2019 POTM Winner
  3. #643
    Jan 2008
    New Jersey
    3,070
    Lot of work, but worth it in the end. I’m interested to see your placement of the box and what you come up with for a bracket. I hope to do this myself some day
    -Phil
  4. #644
    Sep 2008
    Whitestone, NY
    19,891
    Its definitely worth the hassle.
    Cleans things up nicely under the hood, allows you to add and modify existing wiring like placing the horn, headlights and fan relay inside and easily get back up and rubbing if a circuit has a hiccup. No tracking town a fuseible link..just a fuse.
    Kinda annoying if you have to remove the fender brace to access the lid but not annoying if you never have an issue. Honestly how often down one even open up a underhood fuse box in their newer cars?
    I think I did it once in my mercedes to swap a cig lighter to switched power instead of constant (it has that option) and never since.
  5. #645
    Nov 2014
    Evans, GA
    1,727
    Finally got the darn fuse box patched in today.
    And it's about 98% functional. Something is not right with the horn relay, since it engages (but does not sound the horns) when power is applied. I didn't fuss with that circuitry when I was re-pinning the blocks since it appeared to be correct. Essentially I was left with two wires coming off that relay, which is one to the horn pad to ground the circuit, and the other for output to the horns themselves, which those ground to the chassis.
    Only thing I could imagine I did was somehow mislabel the two wires........................................... maybe I answered that right now. Horns = Ground on the trigger side means that relay is gonna engage and mashing the horn pad grounds the circuit and blows the fuse. I'll check that tomorrow. Definitely too late now to try and be honking the horn.
    Otherwise, it hasn't caught fire yet, none of the other fuses have popped, and everything seems to work okay. The headlights and e-fan relays were moved into the housing and those seem to work just fine.
    As far as mounting this one went, I was very lazy, got some rigid exhaust strapping, bent two legs into a shape where it kept the box level and then attached the strapping through preexisting holes in the fender liner. It can't move much like that, and when the brace is down, it literally cannot move since the brace sits right on it.
  6. #646
    Sep 2014
    Warren, MI
    6,245
    If you're getting power to the horns but they're not honkin', try adjusting the screw thing on them. I had that problem with my TC an Ashley's TC- bumping them sometimes "adjusts" them to open circuit. Also, my horns didn't measure within spec resistance wise. Sustained horn use of greater than 1 or 2 seconds would blow the fuse. First found that out in the middle of road trip, it also takes out cruise control when that happens.
  7. #647
    Nov 2014
    Evans, GA
    1,727
    Nope, no power at the horns. I definitely hooked the wires up backwards, so now the horn works.
    FWIW, I popped the 20 amp horn fuse at least twice with the old relay/wiring setup fitted, and I think I know why now: The contacts were disgustingly corroded. Looked like someone had been dumping battery acid on it. Hopefully that won't be an issue ever again.
  8. #648
    Sep 2014
    Warren, MI
    6,245
    Oh.
    Yeah, the green crusties wreak havoc on things. My neighbors must've hated me while I was fiddling with the horns. They're quite obnoxious in a driveway.
  9. #649
    Sep 2008
    Whitestone, NY
    19,891
    Looking good!
    You have plenty room to grow yet in there?
  10. #650
    Nov 2014
    Evans, GA
    1,727
    Looking good!
    If you mean adding much extra, not really at this point. All four relay slots are used. Horn, Headlights (Hi/Lo relays), and E-Fan are in there. Most of the traditional ATO slots are taken save for maybe four total, there's two open circuit breaker slots, and there's about five open Mega ones. It's fairly loaded up, save for really any crazy, high amp ones.
  11. #651
    40,017
    the +12v wire into the horn relay should connect to 30 and 85. Horn should connect to 87, the horn pad to 86.
    Most of the time you can reverse 85 and 86, but not in a diode suppressed relay. Either way power has to connect to 2 pins or no honky honky.
  12. #652
    Sep 2008
    Whitestone, NY
    19,891
    I see. Same happened to me. Then I installed an additional relay box (factory two banger) and then an aftermarket one (relays and fuses) on a factory bracket that fits right behind the newer inner fender air boxes. I am good now with spares. lol
    If you need more relays spots you can JY search for this factory box and bracket:
    Think it may be a couple year model only thing in town cars around 1998 with a certain option.
Tags for this Thread
