Page 25 of 30 FirstFirst ... 152324252627 ... LastLast
Results 481 to 500 of 584
Thread: My 1987 Mercury Colony Park
  1. #481
    Nov 2014
    Evans, GA
    1,605
    Put everything back together today, it was running good.
    I decided to test the strength of the restrictor and found its cannot handle TEH LOPO WOT WATER POWAH! That thing blew up where it was ďsealedĒ together and sprayed the engine bay all over the place with antifreeze. I thought I sliced a hose until I restarted it and saw it shooting every which way.
    FWIW, all the new hose connections worked great, and the sensors arenít leaking.
    Guess tomorrow Iíll go to the store, warranty return that fitting and do what Iíve seen around here: a 13mm socket stuck in the hose. Iíll also need a hose barb to reconnect the hose, but thatís no big deal.
  2. #482
    Nov 2014
    Evans, GA
    1,605
    "Impromptu dissection of restriction device was performed by forces delivered by the right foot applying more force to the power metering component and under less than optimal conditions resulting in fluid loss."
    I did get to actually look at how this one is supposed to operate. It has the restricting ring in the middle, but uses a coil spring in the large portion to cushion the force of the water for metering I suppose. The end cap was sealed to the main body, but absolutely just blew apart when I floored it. Like I said above, I'll try something else, since obviously this won't hold up very well on our cars.
  3. #483
    Sep 2008
    Whitestone, NY
    19,152
    What the heck is that from again?
    I rev the snot out of my 87 with a mustang heater core flow restrictor and have no issues. If this is something you want to persue (even after the socket trick) that may be the route to go?
  4. #484
    39,270
    The Mustang part works well. Basically looks like a piece of plastic tube with a hole in it. No extra clamps needed, it just sits against the end of the heater core inside the stock hose.
  5. #485
    Nov 2014
    Evans, GA
    1,605
    The piece I broke normally fits mid 2000s Chrysler minivans and apparently some mid 90s GM stuff, including but not limited to H and F body cars.
    I saw the Mustang heater core restrictors after I picked up the inline thing. I think I'll try the socket trick first since it's readily available (and I think I have some extras laying about). After seeing what a WOT run did to that thing, I certainly do want to try and prevent damage to the heater core from that abuse. I don't beat on it regularly, but it's peace of mind here.
  6. #486
    Nov 2014
    Evans, GA
    1,605
    Back in business today. Got a cheapie 13mm socket and a brass hose barb from the parts store. Tossed it all together and now I have a functional assembly that doesn't blow up under hard acceleration. Car now also holds vacuum very well after being shut down, hopefully that line doesn't decide to crack again anytime soon.
    Also, this arrived in the mail today from someone here:
    Not going to name drop unless they're comfortable with that since he wasn't publicly advertising, but he messaged me while I was originally just looking for a spare 85 MPH cluster after having read through this thread, since I have a Town Car electronic speedometer head but didn't want to cut up my OE gauge face. He mentioned he had the 135 MPH unit and a 85 MPH unit and to make an offer for both. I did, and he hit me with the number he was looking for, I waffled around, then finally concluded this wasn't likely something I'd cross paths with again so I agreed to his price and made a deal.
    I think I'll put the electronic hybrid thing on hold since I'm sure once this is installed, I probably won't have it out anytime soon. I already told him it will stay in the GMN family, and if anything happens to the wagon, this will be removed for someone else to have here.
  7. #487
    Mar 2006
    Bedford, VA
    5,668
    The one of one remaining holy grail. Good addition to your car!
    1988 Crown Vic Wagon - daily
  8. #488
    39,270
    Wow, thats a super rare piece.
  9. #489
    Sep 2008
    Whitestone, NY
    19,152
    I want one as wall art. I get chills every time I see one.
  10. #490
    Sep 2014
    Warren, MI
    5,882
    Ehhh, if I stuffed one of those in my Mercury I'd now have to squint to see what speed I was doing. For all intents and purposes I'd only need the first half of it...
  11. #491
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,149
    Now to find a whole box Mercury police car as clean as that speedometer. Even harder to find.Have not seen one anywhere in many years.
  12. #492
    Sep 2014
    Warren, MI
    5,882
    I've never seen one, didn't know those were things. Talk about a unicorn.
  13. #493
    Nov 2012
    Shelby Township, MI
    3,147
    Mostly early years from what I gather. Around '82 and I want to say St. Louis was one of the few that someone said had such a thing.
    ~ 1997 GMC Yukon - wannabe winter DD - returning summer 2020, I finally have an engine
    Gone but not forgotten:
  14. #494
    Nov 2014
    Evans, GA
    1,605
    Decided to add an electric fan for A/C assistance. I was planning on doing a setup similar to the '95-'97 cars with the mechanical fan primary with electric fan secondary, but there's not enough room for all of that in front of the mechanical fan, so instead of using the electric fan as a puller, I used it in a pusher configuration in front of the A/C condenser.
    Since I had originally planned for this to be Aero styled in setup, I only got one 16" fan before realizing my space error. Realistically given front mounting restrictions, maybe two 12" or 14" units would have been more appropriate due to the support bar being present in the dead center of the condenser, but I made use of the single fan.
    It's a Hayden 3700 unit. Single speed rated around 1100 CFM or something close to that.
    Wiring is a little spaghetti, however I eventually plan to eliminate most of that with a later style high amp fuse box used on the later cars. I'll also be integrating the protected fusible link circuits into that box as well.
    Regarding activation of the fan, the trigger wire is actually hooked to the constant powered side of the A/C low pressure switch (not the switched side). Anytime the HVAC controller is set to A/C Max, A/C Norm, Mix, or Defrost, it'll trigger the relay turning on the fan with the car on. The fan circuit is protected by a 30 amp fuse.
    While I didn't take the car out to see how well it worked in traffic, it certainly seemed to do a good job just even being in the garage and moved plenty of air across the condenser and a fair amount through the radiator.
    I did not want to go with a full electric fan setup replacing the mechanical fan since I haven't been let down by mechanical fan yet and if the electric fan fails, I don't lose cooling ability. Using an electric fan to help with additional cooling demand in this instance seemed to be a more ideal route.
  15. #495
    Sep 2008
    Whitestone, NY
    19,152
    Were you having issues with your ac? If so I am curious if it helps out.
  16. #496
    Nov 2014
    Evans, GA
    1,605
    A/C is typically nice and cold when moving at speed and the weather is decent. However, with most days being over 90+ and high ambient humidity (usually 40% or greater at any time) and being in slow moving traffic, it'll get cool but not cold, even with line pressures being within normal ranges for R134a systems. Couple that with trying to remove hot cabin air, it's just not a great mix when the system can't dissipate heat away from the condenser at low speed. This should help in that department to keep air moving across the condenser and towards the normal mechanical fan.
  17. #497
    39,270
    Shoving more air across the condenser can't possibly hurt AC performance. You can't over-do it. Even if it doesn't drop outlet temps by a great amount it will drop high side pressure, which is good for the compressor.
  18. #498
    Mar 2006
    Bedford, VA
    5,668
    Doesn’t help that you’re cooling the expansive guts of a wagon. I’ve always thought wagons should have gotten a higher output HVAC system. I’d imagine it’s quite toasty in the jump seats in the summer heat. They did it with dentside F-Series trucks (and Broncos), they could have done it on a Panther.
  19. #499
    39,270
    or even just rear vents would have helped with the greenhouse effect back there.
  20. #500
    Nov 2014
    Evans, GA
    1,605
    That's probably by far the worst issue going here. Days where it's nice (spring and late fall), I can easily go with flipping open the vent windows and rolling the tailgate window down and have a nice fresh breeze through the whole car. No stale air. Right now the air is stagnant, and all of that air just hangs in the interior. Driving with the windows down for a minute gets some of it out, but you're still introducing humid, hot air right back in after closing all the windows.
    Getting a good tint job is on the list, since the car has some very old tint, but it's starting to bubble up and it's not very dark, so while it may do something, it's not a whole lot.
    Unfortunately without re-engineering the car, poor rearward cabin ventilation will just be a thing, but it's been a thing since these were new, but I figure I can at least combat a little bit of a issue to at least improve forward comfort.
Tags for this Thread
