I would like to do dual exhaust on the '87. It helped on the '97, and I'm sure it can help here. Now I've had downright shitty luck working on exhaust, but I would like to change that by actually looking into what I need before I get started.
So the car currently has catless down pipes that feed into a Y-Pipe that goes to a factory looking muffler and out the side exit exhaust behind the rear wheel. I do have the ability to purchase a set of catalytic converters from a late '80s Town Car for a good price along with a '91 Town Car H-pipe and muffler set. I want to add the cats back since the exhaust reeks and it'll simplify installing an H-pipe as it would then be a bolt on deal.
My question is can I use that '91 H-pipe or is will the fitment be wrong on it?
Also, can I take a sedan left tailpipe, cut it after it goes over the rear axle, then just add the 90 degree turn so it'll have a side exit exhaust?
All I'm trying to do is make a stock engine breath a bit better. I have no real performance plans, nor am I trying to make it loud.
