'84 is sagging even with next to nothing in the trunk, but a full gas tank (and sits level when the tank is near empty). I'd like to bring it up a bit, not really rake it but maybe a bit higher in the back than the front. I typically carry somewhere between 50-100lbs of stuff plus the steel spare (normally a donut but if I'm going out of the city I switch it out for the full size).
The Lincolns are obviously a little longer than the Fords and Mercs and therefore put more weight on the rear axle; I'm familiar with the effects of the CC817 and CC819 on both of my Grand Marquis (83 2dr and 91; found the 83 did not lift as much as the 91, not really sure why. Steel bumper?). I know the CC819 is way, way too much for the Mercury, it rakes it way too aggressively.
What's the option that's most likely to give me the results I'm looking for? Ideally I want to have the rear just slightly too high when completely empty of all cargo and low on fuel, and sit more or less level with everything plus perhaps one rear seat passenger.
Kinda tempted to pull the CC817s out of one of my other cars and see how it sits on them, but maybe someone has already done that with a Box Lincoln and can comment on it before I do. I feel like, based on the extra weight of the car, it will basically sit at the same height it does now but be more resistant to further sagging, which doesn't really accomplish the goal.
