Looking to swap out my '85 Grand Marqs frame (rear driver side rail failed the hammer test) to something better AND more structurally sound come spring. I've heard from various sources that body mounts, bumper brackets, and such will all bolt right up. Only issue I can see are the frame lengths. Were the '98+ Grand Marqs still 2 inches longer at the front like they were on the boxes? What about '98+ Town Car frames vs the box Town Car frames? Or were they all the same after '98?
Also what about rear ends and rear brakes? Would an aero rear end bolt up to a '98-'02 frame? How would all this affect sway bar selections and other suspension parts? (I.E. would I use an addco aero rear sway bar on my aero rear end on the '98-'02 frame or should I use the addco whale sway bar?). Thanks for any help you guys can give.
