Timing was set with the SPOUT unplugged yes?
Need more help...
crank sensor? pinched fuel line? does the fuel pressure say up when you give it some throttle? *grasping at straws*
If it was the EGR valve it wouldn't idle well or not even at all. A quick test of that would be to pop the vacuum line going to it off, cap it and then apply some vacuum to it. You'll know if it opens [and isn't clogged] if the idle changes by becoming stumbly and such.1985 LTD Crown Victoria - SOLD
Crank sensor is right behind the timing marker. make sure it's plugged in properly. They rarely go bad unless they get damaged.
You should get slightly better economy with that connected. Also was the line caped?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by sly View PostCrank sensor is right behind the timing marker. make sure it's plugged in properly. They rarely go bad unless they get damaged.
Videos have to go to Youtube or some other image / video hosting thing.86 Lincoln Town Car (Galactica).
Originally posted by colejackson72 View PostIs there a way to post videos on here?
(from the video dialog on the full desktop site)
Supported videos include:
Hulu YouTube (Long) YouTube (Short) Vimeo Dailymotion Metacafe Google facebook
Then just link to it here with the video tags.
Originally posted by gadget73 View PostIts a 302. No crank sensors after 83 or before about 1996.
