Interesting. I'll recheck but I remember noticing that the rear door didn't have one either.
How to adjust door latches?
85 LTC, Dark Canyon Red?/ 3.55 open/ HPP Wheels/ 4 Tone Horns/ ***POTM 5/2017*** SOLD
06 LTC, Silver Birtch, Fully Loaded [ The Daily ] ***POTM 4/2018
97 Mountaineer, 5.0 H.O. , 135k, Now with functioning window
89 LTC , Lowered, Straight Piped, (SOLD) 88 LTC (SOLD) Rough and Dirty, 2000 MGM, 2002 MGM, 96 MGM, 2005 MGM LSE (SOLD)
When you remove the strike to replace the plastic would be the time to lower the door height.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by sly View PostI personally like the clunk... but that's just me... beater gonna beat
Originally posted by 87gtVIC View PostDoes not look like the plastic bushing is over the striker. You need that!
Originally posted by knucklehead0202 View PostThis. I like the solid "chunk" sound they make, although the regulator rattle inside is kinda dumb. If I wanted some jap-crap, i'd buy a stupid Honda and drive around in a boring buzzbox. Not sure how much of a lexus you're going to turn a 30-year-old Ford into, but it won't be easy mate.
Originally posted by LSE_Dave View PostNot a single striker on the car has one.1985 LTD Crown Victoria - SOLD
Time for your next job.~David~
Did you ever dynamat the inside of the doors? I've always wondered how much additional sound deadening would help with interstate wind noise. The '87 needs it bad in the roof (sounds like a house with a tin roof when it rains), but I figure the doors could benefit some.
FWIW, the seals around the doors and windows are good. I know the Boxes will never be as quiet as the later cars just by the nature of their design.
It does help, but the foam crap that goes between the door and door panel was also missing on my car. I did both the outer door skin and the inner, so its replacing the foam. A lot of what it does is help get rid of that hollow sound when you shut the door. It also helps a lot with the amount of air blowing around the door handles.
Most of the noise I used to get was from bad window run felts. Its replaced now, but there is a small gap where I messed up a joint and i can hear it through that spot now.86 Lincoln Town Car (Galactica).
