2003 Town Car - always on radiator fan
    2003 Town Car 40k Miles the one I bought from FL. Radiator fan always on. Hvac off, fans running at low speed. AC on, fan stays same speed. This fan is always on - I don't get it.
    What should I do to fix this? Should I start by using a test light to see if the PCM is commanding the fan on?
    -Nick M.
    Columbia, SC
    Wild guess, either the relay is melted or the temperature sensor is dinked and it thinks its hot all the time. I think the overheat signal turns on the high speed fan and probably shuts off the AC as well. I think the relay should live inside the under hood fuse box. Try swapping it with another one to see if the problem stops. If so, replace the relay.
      03 should be controlled by PCM all the way using the ECT as the temp sensor. I would check the line coming out of the low speed fan relay to make sure it's not grounded somewhere (the wire that goes from the relay to the PCM). I'll get the EVTM diagram of that crap in a bit.
        Nevermind. 2003 is the beginning of the pulse width modulated clusterF! It's totally controlled by the PCM and has no relays which means some trigger is tripped if it's always on. This could be a bad sensor. Check for codes as some of those sensors will not trip the check engine light by themselves.
          Ok I'll get the forscan app loaded and check it out. Rhanks
          -Nick M.
          Columbia, SC
            If you get codes P1474 OR P0480, here's the diag process from the service manuals I have.
