Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Thread: Bump/Miss/Hesitation in engine
  1. #41
    33,881
    never seen that before.
    91 Lincoln Mark VII LSC SE, triple black (Timewarp) - poly front bushings, KYB struts and shocks, Holley SystemMax1 lower intake, SilverFox AOD valve body, 246k and counting
  2. #42
    I post a lot...
    Mar 2007
    North Las Vegas Nevada
    2,067
    I would not use Platnum tipped spark plugs due to the need to use a "hot" ignition system as in a race car not a street car with a "street" ignition, I speak from experience as I pulled out many platnum tipped spark plugs when customers complained of rough idle. Some cars do require the platnum tipped spark plugs to run properly.
  3. #43
    Member
    Jan 2012
    Chesapeake, VA
    125
    Here is the document that Jasper provided regarding the PCV vacuum supply reroute. Makes sense that how it was routed before would have cause issues on the #8 cylinder. Hopefully this new routing will eliminate future problems.
Name:	Jasper Engines PCV reroute.jpg
