Probably so and the fact that it used about a half quart of oil on a trip from Chesapeake to Charlotte and back.
Bump/Miss/Hesitation in engine
Hopefully my picture isn't getting confused with the OP's pictures. You could list every possible cause in my case and they would probably all apply.Vic
Originally posted by DerekTheGreat View PostCheck engine LIGHT. Sorry, that irritates me to no end
How many miles? Does it burn oil? Could be it needs valve stem seals, these lopos tend to foul out the cylinders closest to the firewall. Ashley's old '89 fouled out the driver's side plug and produced the exact same symptoms you described.Originally posted by gadget73 View Postlink doesn't link proper. wants me to log in or something. Try uploading them to here as an attachment.
two rear plugs oil fouling is common on engines with wear. Not sure if it comes through the valve seals because of the tilt of the engine, or through the PCV system because of blowby but either way thats where you see it. Is the screen in place under the PCV valve? You'll get a lot of extra oil through there if the screen is missing.Originally posted by MattDoscher View Post[ATTACH=CONFIG]47478[/ATTACH]
[ATTACH=CONFIG]47481[/ATTACH]
Had to re-size the pics to get them to post.
This is a new remanufactured engine. I'm assuming the PCV mesh screen is in place, it's nearly impossible to get back there to confirm w/o taking off the upper intake. What do you think of the pics? The first two are the "good" ones and the last two are plugs 4 and 8 with #8 being on the right and the worst of all of them.Originally posted by gadget73 View Postold valve seals or worn guides could explain that.1985 LTD Crown Victoria - SOLD
*Update*
So Jasper has advised my shop to make some changes to the PCV system and relocate the PCV valve. Apparently this was either a running change or a TSB not sure which that Ford instituted at some point. I have never heard of this but here is a link after doing some quick Googleing.
http://www.fordtruckclub.net/forum/s...ead.php?t=6049
Have any of you heard of or done this modification? I gave my shop the ok to do it.
Matt
long hose is long.
never seen that before.86 Lincoln Town Car (Galactica).
I would not use Platnum tipped spark plugs due to the need to use a "hot" ignition system as in a race car not a street car with a "street" ignition, I speak from experience as I pulled out many platnum tipped spark plugs when customers complained of rough idle. Some cars do require the platnum tipped spark plugs to run properly.
