So I found a fancy kickout pan that I like but not sure if it'll fit on our silly cars. Made for fox so it's rear sump. Anybody have a yay or nay on this one? http://www.ebay.com/itm/361930641586...%3AMEBIDX%3AIT
Oil pan?
Almost every oil pan made for a fox body should work. The stock cross-member is in the same place as far as the oil pan is concerned IIRC.
Now hanging low is another story. They have the depth of 7.5 inches. Measure from the block to 7.5 inches and compare that to where yours currently sits. Then you'll know about how much lower it will hang.
oh yeah... you'll also have to get a dipstick that will work with that thing and maybe a longer oil pickup for the oil pump as I'm sure it is a little deeper.
Most of the other high-capacity pans are 9" deep, which is why this kick-out pan seemed attractive. Going to try and spend a little car-time this weekend so i'll jack the bitch up and do some measuring. Yeah already looked up the oil pickup and dipstick. A stock dipstick can actually be used but it's a pain and doesn't sit right with my headers anyway so i'll probably get a new one anyhow. Just trying to get every last part I need for this motor. Thanks guys. Will report on what I find out.
I use the Canton road race pan which is the same design. Only issue is the rear sump drain plug is a bit difficult to deal with because it is so close to the cross member. Eventually marked the cross member when I swapped THE ENGINE drilled a hole in the cross member so I COULD ACCESS the plug through the cross member. Bottom like it should fit fine. My self prefer road race pans.
Looking at the pics it may not have the rear drain plug issue. It appears its on the passenger side rear. Mine is on the drivers side front of the rear sump same side as the pic showing the plugs for the aftermarket dip stick and oil temp bungsLast edited by turbo2256b; 04-26-2017, 01:21 PM.Scars are tatoos of the fearless
