Results 1 to 17 of 17
Thread: '92 - '97 Rear Disc Upgrade?
    Nov 2006
    Dirty Jersey Yo!
    7,629
    Question '92 - '97 Rear Disc Upgrade?
    Curious; what do I need to take off of a '94 MGM rear to convert to discs on my '86 CV? I imagine I would have to take everything down to the backing plate. Is there anything else that I need; aside from taking the whole unit off of the car? I am trying not to have to rebuild another rear for my CV.
    THank You
    Birdsboro PA.
    16,767
    need backing plates,parking brake cables and brackets, calipers for cores.
    going to have to take the axles out of the rear at the yard to get the backing plates off.
    Nov 2006
    Dirty Jersey Yo!
    7,629
    Thanks Scott!!!
    In the end, I will probably be rebuilding the axle I take off of the Aero.
    35,720
    Aero rears are slightly wider. Fits under a box fine, just something to be aware of if you've got really fat tires that don't have a lot of wheel well clearance though. Its something like 3/4" per side.
    Plenty of clearance with "stock" tires and 255/50-17's I use
    LOUD EXHAUST IS FUN! AM I SHOUTING?
    1989 Country Squire - Twilight Blue, 111k miles, towing package with 3.55 trac-lok...347 stroker
    35,720
    More of an offset thing than strictly a width one I suppose. Just something to keep in mind. If there is little clearance now, moving the wheels outward ain't gonna work.
    Fort Wayne IN
    5,596
    Does the stock proportioning valve provide the correct pressure?
    Feb 2015
    3,124
    Yeah, in theory it's less than ideal, but in reality it still works quite well.
    35,720
    It holds some pressure on the rear brakes, and they end up wearing faster. There are also some other details that make it non-ideal. It does work though.
    Dec 2011
    Yonkers NY
    3,433
    Do you have the pressure/proportional valve screwed into the master cylinder on the 86?
    Feb 2015
    3,124
    '86 has the all metal (be it steel or aluminum) master, the prop valve is not attached to those, instead it lives alone on the bracket bolted to the frame rail right under the brake booster. Can't do what you're thinking with that design.
    35,720
    yeah, involves a re-plumb. Can be done, has been done on my car, its just somewhat annoying. Its worth doing, but if the lines and/or MC are not in questionable shape, it can be put off.
    Dec 2011
    Yonkers NY
    3,433
    ok
    Southern
    Apr 2013
    Columbia, SC
    766
    I have everything short of hard metal brake line so you can upgrade to disc. Ford oem parking brake cables for 1993 Town Car. Backing plates, calipers new remans, new pads, brake hoses...just need rotors
    -Nick M.
    Columbia, SC
    1966 Ford Country Squire - 6.4L 390 2bbl/C6 - ~85K miles
    1989 Mercury Colony Park LS - 302 V8- 188K miles.
    1990 Lincoln Town Car Signature Series - 302 V8- 102K miles.
    2003 Lincoln Town Car Signature Series 3x - (42K, 79K-totaled, 222k)
    Apr 2015
    Southern Commiefornia
    1,797
    Quote Originally Posted by TecNickal View Post
    Ooh how much you want for all that shizz? I never have time to screw around at the junk yard. Is there a hardline that'll fit or does it need to be fabbed? Rotors are no biggie.
    35,720
    You'll have to run line yourself. The NiCopp stuff is pretty easy to deal with.
    Feb 2015
    3,124
    Run your own line. Several ways it can be done, I think the factory aero line routing is kinda retarded but given that ABS cars need two lines anyways I can see why they did what they did. On a non-ABS car I like retaining the box setup and just attach the caliper hoses at the ends where the wheel cylinders used to go, even if reusing the factory box lines is not possible due to rot or other physical damage running two short lines on the axle is a whole lot easier than running a long line all the way across the frame to copy the factory aero setup. If doing the box lines with aero ends be careful how you run the caliper hoses, under no circumstances do you want them to run on top of the axle where they can be hammered on by the frame should you bottom the suspension out.
